Well, I have no means to measure the hex inverters,but I prefer potatosemi over NXP. I've been using their product for more than a decade. On Andrea's clock board, I recommend using single inverter only. Paralleling the inverters will degrade the sound. Just my 2 cents.
Poting
Poting
Hi, will there be another group buy soon? I am still looking for a SC-cut 11.2896mHz. Thanks.
Yes, I will start a new GB as soon as the new Driscoll oscillator board will be ready.
Thanks, Andrea. 🙂
+1
Looking forward to it, Thanks Andrea
Ciao Andrea, the new Driscoll oscillator will be two clocks with oven?
Grz e crdl slt
Felipe
Grz e crdl slt
Felipe
The new Driscoll will be single clock on one board, if you need two frequencies then you need two boards.
Now I cannot tell about the oven, it will be with or without, depending on the measurement.
Andrea
+16v on TWMMC-Oven
Question… How much variance to unregulated 16v is acceptable on the Oven PS?
EG is anything in range of 15v - 20v ok? What are acceptable limits?
You should not exceed 16V to avoid too much dissipation in the regulator, so the acceptable voltage range should be 14v-16v.
andrea_mori
please inform Parts in stock .
No crystal in stock now, I will start a new GB as soon as the new Driscoll oscillator will be ready.
Hi Andrea,
I just stumbled upon this groupbuy and I just happen to get back to digital. Is this still available? Hi have ians original fifo and wanted to know if i can use this clock. Im currently using a generic xo on mine and need to upgrade. I need a 11 and 12mhz clocks. Can i still buy these? Can they be used with ians fifo?
Best regards,
Tubo
Best regards,
Tubo
Hi Andrea,
Best regards,
Tubo
You can use this clock, but max. 88.2 and 96KHz sampling freq., if I m not wrong.
It will be a big update, music will be very smooth and sweet, with big space.
Hi Gabor80,
Thank you for the response. Are you using it on ians fifo as well?
Yes, with 45/49 MHz clocks at the moment, but I ve got the 5/6 MHz Sc-cut crystals recently, the next project will be these crystals to start working.
The Ian's Fifo min. multiplier is 128X, so with 5/6 MHz it will just work on 44/48 KHz.
The Ian's Fifo min. multiplier is 128X, so with 5/6 MHz it will just work on 44/48 KHz.[/QUOTE
Please keep us posted on your progress, im very interested on how you will implement the clocks to the fifo. Im not really sure how to proceed with my project..
You’re using fifo v1 or fifo II?
- Group Buys
- The Well Tempered Master Clock - Group buy
