For Sale preferred in Europe - PCBs and - LDR Pre - USB Bridge
Joined 2007
For Sale preferred in Europe - PCBs and - LDR Pre - USB Bridge - IAN Canada FIFO II
FOR SALE - preferred in Europe:
From all the things I have more than one I decided to let some go, if there is interest. All prices are without shipping / paypal. Shipping for PCBs just cost a few €. I'll add photos in a second post.
#ZDRs LDR Pre - I bought it ready made, so made by Neb himself: Complete with everthing you need. The shown chassis is not for sale! Just for reference. Arduino has got latest firmware from wineds, which allows to choose Pot Resistance directly when starting up.
Has got nice amber LCD 2*16 which fits nicely chassis
https://www.ebay.de/p/DIY-Aluminum-...rstärker-Gehäuse/12024984819?iid=251677550408
Be aware, if you use this chassis, you have to modify the rear plate!
If you wish, I can rename the in and outputnames, as you like!
Meanwhile there is a version MKII available, which is slightly more comfortable and slightly more precise.
Neb sold it in March 18 for 180,- €. I sell it for 110,- € now.
#Allo USB Bridge - Have two of them and like them very much, but need just one. It is virtually unused. When I first heard it vs the Pi USB, I was almost shocked by the quietness, my AYA DAC could put out.
With acrylic chassis and all the original content I let it go for 105 € (Was and is 155) Pics will follow! Sold
#Nelson Pass Sony V-Fet Amp PCBs from the Store - 1 Pair Very good DIY Store Quality 1.6 mm / Gold 28 € sold
#Whammy - Pass DIY Headphone Amp PCBs 3 pcs. Very good quality Elecrow 160*220 1.6 mm / 1oz / Gold 22 € 2 sold to BDL - 1 still available
PCBs are made from latest published Gerbers. This released Gerbers are missing the input resistor and I always solder them directly onto the input RCAs. Works great!
#DCB1 Hypnotize - Salas/CRT/Teabag PCBs - pretty good K170 Stereo Buffer with shunt regulator 4 pcs. Very good TeaBag Quality 126*68 1.6 mm / Gold 10 € 2 sold - 1 available
#DCB1 Mezmerize - Salas/CRT/Teabag PCBs - pretty good K170 Stereo Buffer with shunt regulator Vol. Pot and Input Selector 1 pc. Very good TeaBag Quality ?*68 1.6 mm / Gold 14 € sold
#B1 K170 stereo Buffer PCBs - original as designed by Nelson Pass - Pass DIY Gerbers. 1 pc. Very good Quality from GB 1.6 mm / Gold 10 € sold
#AAK's SymAsym DTV Rev-1.3 PCBs Class AB amp mono PCB including PSU 1 pair Very good Quality from AAK 149*75 1.6 mm / HASL 10 € sold
#Pedja Rogic TDA1541 Discrete Diamond Non Feedback I/V Stage PCBs 1pc. Very good Quality from DVB Project 110*95 2 mm / Gold 10 € Sold
#Salas Shunt Regulator PCBs for TDA1541 Layout DVB Project +5V/-5V/-15V 1 pc. Very good Quality from DVB Project 146*114 2 mm / Gold 10 €
#PCB Salas SSLV 1.1 BIB PCB shunt reg 2 positiv/ 1 negative regs 1 pc. Very good TeaBag Quality 128*127 1.6mm / Gold 18 € Sold
#One single negative PCB Salas SSLV 1.1 BIB PCB shunt reg 1 pc. Very good TeaBag Quality 1.6mm / Gold 5 € Sold
#Minikits for SSLC 1.1 BIB (do only sell these with one of the boards: pending
BJT + (for <= 5V) 2 pcs. 12 €
IRF + (for > 5V) 1 pc. 12 €
IRF - (for < -5V) 3 pcs. 12 €
All Sold
#CRC Class A Amp PSU PCB - layout by CVILLER 1 pc. Good Quality by CVILLER 180*80 1.6 mm / HASL 8 € sold
#Soft Start Board from DIYStore 1 pc. Very good DIY Store Quality 110*55 1.6mm / Gold 6 € sold
#CRC Class A Amp PSU PCB - Designed for FW F4 - 1 pc. Very good Quality from German DIY Forum Member Nagard 178*170 1.6 mm / 2oz / HASL 15 €
Sold
#Ebay FW CRC Class A Amp PSU PCB 1 pc. Quality from Jims Audio 142*126 2 mm / Gold 10 €
#Jeff Young Double Rail / Decoupled Stereo CRC Class A Amp PSU PCBs 5 pcs. Top Quality from Elecrow 147*110 1.6 mm / 2oz / Gold 14 €
#M.Johnson/GTOSE/Prasi CAP-MX Trough Hole Design PCBs 4 pcs. Good Quality from Elecrow 90*80 1.6 mm / 1oz / HASL 5 € 2 pcs. sold to BDL - 2 still available
#M.Johnson/GTOSE/Prasi CAP-MX SMD Design PCBs 6 pcs. Top Quality from Elecrow 62*46 1.6 mm / 1oz / Gold 3 €
#IAN CANADA FIFO II board 1 pc. 68 € sold
#IAN CANADA DUAL XO II board with 45/49 XO's 1 pc. 32 € sold
#IAN CANADA SPDIF interface board 1 pc. 44 €
#IAN CANADA Finished FIFO Isolator board V2.5 1 pc. 22 € sold
#IAN CANADA I2StoPCM converter board V2 1 pc. 40 €
Pics
Pls see the names of the pics, when you put the cursor over the pics.
More Pics
Again, cursor over pic shows itemname. Except for Jeff Youngs PSU. This has kept the pic number.
PP in Europe for a up to 50g letter is 1€70. This ist just for a small board. Everything else is above that. For a registered letter add 3€70.
Everything elso is 3€70 for the letter and if registered is asked for, add again 3€70.
