John Curl's Blowtorch preamplifier part III
The one bothersome thing about this is a sine wave mathematically goes on forever, and music consists of notes that start and stop.
^ I think you may have hit the nail on the head as to why some people have a problem with it :)
Not quite.
As you have seen stated by Bruno - "If you test a magnetic core with a sinewave the distortion looks a little like soft clipping, perfectly benign. But what came out of tests on iron parts in loudspeakers was that hysteresis has a long term memory so you can get intermodulation between things that happen now and things that happened 10 minutes ago. With music this distortion sounds like half correlated noise."
Maybe a different test signal or different approach is needed for magnetic cores & JN could pitch in here?
But the general principle is that not all conditions that are met in audio are necessarily covered by the standard sinewave testing & FFT analysis
Read the full interview (it's worth reading), rather than carefully selected out-takes.... :) Then you will see what he was on about..
Good advice :D
I define an accurate amp as one that doesn't distort the signal. Feedback, for instance, reduces IMD.
Scott, if you read the interview you will see this about feedback - I've quoted the whole exchange so as not to be accused of "carefully selected out-takes"
Executive analysis - loop gain of 75DB all the way upto to 20KHz means that high amounts of feedback can operate right up to 20KHz & not run out before this.
As he says "I suspect most basic class AB amps have a loop gain of 75 dB, but only up to 100Hz or so, then it starts dropping."
"For a linear amp design with a standard 1st order compensation to hit 75 dB at 20 kHz it’d have to have a Gain Bandwidth Product of 110MHz. Two-pole compensation is the highest I’ve ever seen in a class AB amplifier and even then 76 dB at 20 kHz is pretty astronomical."
So, yes, Scott feedback reduces IMD but it seems of limited effectiveness in a lot of normal amplifiers
Bruno: It would certainly explain why the Eigentakt circuit sounds so much cleaner: the extreme amount of loop gain reduces the sonic footprint of the output choke. The low harmonic distortion, most of which is power stage related, is simply a side benefit. It would also mean that directly trying to reduce power stage distortion, say by using faster FETs, is not going to improve the sound anywhere near as much as improving loop gain.
Lars: Wouldn’t you say that speakers with drive units that explicitly tackle hysteresis distortion like ours and like DALI’s, are much more revealing of the differences between class D amps?
Bruno: I’d say so.
Lars: I’m going out on a limb here but maybe there is a wider class of “memory” distortion effects that are completely ignored when you do sine wave tests. Why shouldn’t similar effects occur in capacitors? And thermal effects in class AB amplifiers are also notable for being very audible without showing up on a THD plot.
Bruno: They do on an IMD test with a low and a high frequency but I take your point. There could be more ahead when we go looking for memory effects. On the other hand, the Eigentakt amplifier has so far survived all subjective shoot-outs so let’s say that any undiscovered effects must be rather subtle.
Lars: Not subtle maybe, but sitting inside a feedback loop with 75 dB gain and therefore subtle now. It helps when you have that, it can save you a lot of discovering and fighting every individual distortion mechanism. I’d rather put that effort in the speaker driver where sadly we haven’t got feedback or suchlike.
Bruno: People are shouting “motional feedback” at their computer screens now.
Lars: Motional feedback systems are quite band limited. I haven’t seen any that work above 200Hz. So the IMD that the bass would cause in the mid-band is completely impossible to solve using just motional feedback. And then there’s the Bode Inequality you know. Things get worse outside the loop bandwidth. And even with perfect motion there is still output from the surround which, shall we say, is not necessarily linear. By the way, maybe you ought to stress that the 75 dB loop gain of Eigentakt is all the way up to 20 kHz.
Bruno: Yes otherwise it doesn’t sound all that impressive, does it? I suspect most basic class AB amps have a loop gain of 75 dB, but only up to 100Hz or so, then it starts dropping. For a linear amp design with a standard 1st order compensation to hit 75 dB at 20 kHz it’d have to have a Gain Bandwidth Product of 110MHz. Two-pole compensation is the highest I’ve ever seen in a class AB amplifier and even then 76 dB at 20 kHz is pretty astronomical. I doubt if anyone with strong opinions against feedback has ever heard an amp with a lot of feedback.
Not your ears? I can't remember, did your friend hear the same thing?
My new Halo was hooked up by the time he came around, but the halo is now in for diagnosis/repair so the yammie is back in play.
Only issue I’ve got now is my replacement tweeters (although same design) won’t take the abuse like the original burhoes.
Thanks to pavels 20/22khz test tone one was relegated to ‘Harley parts’ box :D
So unless I find a original replacement it might not be repeatable.
No, it is not awesome. The thesis is quite poor and useless with current designs.
Maybe we need to take a better look at our amp design roots?
There’s mention of a point past a distortion peak (clipping?) that when pushed past it comes back to linearity.......although it was referencing tube amps I believe I’ve experienced this with my SS Yamaha.
May be he is talking about feedback? Tubes/fet, when zero feedback, distortion is only H2. When you increase fb the high orders also increased but then fall again with lots of feedback. BJT otoh, high orders are high even without fb (I have never liked class A bjt amps).
Unfortunately it does come back to auditory perception & psychoacoustics, no matter how much people want to avoid this elephant in the room.
Psychoacoustics to audio is like quantum theory to Physics (if you know what i mean).
So my question was about this factor - if indeed, IMD is the determining factor, do we need to re-examine audible thresholds for IMD or do we need a different way of measuring such distortions
The threshold is not the point, imo. Psychoacoustics will talk about masking, correlated versus uncorrelated noise/distortion.
It seems to me that I and Bruno have a little similarity in design approach? There is issues with high order distortions. Choosing tube/mosfet and zero feedback designs will eliminate this issue but there are other issues with H2.
So, feedback design is chosen. In order to avoid the issues with high order distortions, the feedback is maximal. This is possible with using high bandwidth transistors. When we maximize feedback and open up the amp to ultrasonic, we need to know how to deal with it, especially understanding stability and compensation. Bruno talks about advanced loop control. Basically this is to master stability art because that is the consequence you're willing to take when you approach amp design this way.
And how exactly did you draw this conclusion from what Bruno (correctly, BTW) said?
Sound Separation
Have you read reviewers talk about sound separation? Usually using words such as "you can follow each instrument individually". When I read Srajan's review about Bruno's class D amp I didn't see this aspect mentioned. I suspect, class D is not good in term of this quality aspect. I'm happy because I found this quality aspect is even more important than 'transparency' and other aspects. Currently I'm investigating this 'separation' aspect. Once I know how to maximize this quality aspect, it will be a killer amplifier.
Fourier transforms of steps and impulses. ( and you can multiply the step and the sines to give sines that only last as long as the step, and then multiply by an exponential to give a decay, etc.).
TheFourierTransform.com - Step Function and the Signum Function
And then you can look at the list of transforms on the next page.
Learn the math before you poo poo it.
I dont understand how people who use, or believe FFTs are real, and can acuratly measure THD, and IMD, dont think fourier transforms can be applied to music.
Dunno, how about photosynthesis as an analogy? We don't know quite how it works but it does.
Thresholds are still a large part of that though, unless I'm missing your point?
Quite the contrary, the Fourier transform assumes infinite sine waves.
No, it doesn't. One needs to assume periodicity only if wants a Fourier series representation, expressed as an infinite sum of sines. For aperiodic signals, the Fourier transform provides a representation in which the signal is, in the general case, an infinite sum of infinitesimal sines. Otherwise said, for an aperiodic signal, the Fourier coefficients are integrals rather than closed form expressions. A Fourier inverse transform exists and can be used to re-build the original aperiodic signal from its Fourier transform.
The reason why Fourier series coefficients are commonly used in engineering (from audio to optical spectra analysis) is that switching to the Fourier transform doesn't provide any extra insight, for the common electrical/optical time invariant circuits.
If you think audio, specifically, would benefit from such a different (aperiodic signals Fourier transform) approach, then this would be one of those extraordinary claims that needs extraordinary proof before engaging in further work. Until such extraordinary proof is provided, we tacitly extend our signals to periodicity and use our spectrum analyzers to determine circuits performance.
How do you know a smaller IC is less problematic? I have a 3 mm^2 ARM Cortex M4 with Bluetooth low energy radio in the same package on my desk. PMIC same thing, almost as small but 5 switching regulators. Those are all chip scale packages.
Human communication is context based. I considered the context given by the modified PCB inside of the DAC and its "EMC modifications" when answering syn08's question about the "smallish ICs" .
I responded with:
Could be, that "smallish" ICs on the board are radiating (and receiving) higher in the frequency range and overall cause less problems due to lower currents switched on/off.
you might note the "Could be" at the beginning, which could (at least I hoped so) in a sufficient way indicate the speculative nature of my statement.
So, I don't know and I didn't pretend to know.
FUD, you know, a theory with no evidence proposed by someone who doesn’t seem to know what they are talking about in order to plant seeds of doubt in support of undefined problems.
IOW, what you and syn08 were trying was classical FUD although you might have to reread the (classic) definition. ;)
It is still useful to remember that measurement with sine-waves (you know single-tone or pure-tone :) ) in the usual way (means using a distortion analyzer or voltmeter) is considered as so-called "steady state" measurement.
@ gpauk,
Mmmmerrrrilll? Pedantic? Shirley not....
Bruno also says he thinks that the Purifi amps are pretty close to perfect.
Looking at the way they measure, it's hard to disagree on any sane basis.
Certainly close enough that any discussion of what needs fixed moves to speakers.... Which is hardly rocket science... :)
Besides, that it is anecdotal information, the argument about the already sufficient measured approximation to perfection is used at least for four decades, usually in combination with "that now ......." while the former generation (back then already near enough to perfection) wasn't .
Although it will be most probably true someday (maybe indeed already today) the reasoning as such is questionable.
I responded with:
Otherwise said, you accept the premise that shielding ICs does something audible for the DAC, then (while explicitely admitting you have no idea about the topic) try to extend this to smaller ICs.
Once again, if this is not FUD, then nothing else is. Of course, combined with an ad hominem directed to, and intended to discredit, those that do have an idea about the topic.
It's ugly and yet another proof of the disgusting intellectual dishonesty you are practicing on public fora. That, because I can't imagine you really believe in what you are preaching. You are not stupid enough for this.
More FUD. A "steady state measurement" is by definition a measurement taken on a DUT, when the DUT doesn't change in any way during the measurement. We call such a DUT a "time invariant system" and if somebody claims that audio electronics is not time invariant, it better come with some extraordinary proof before asking to be taken seriously. The most common examples of time variant systems (and for which a local time invariant approximation is not good enough) are the planet Earth thermodynamics and aircrafts in flight.
