UGS with LSK170/LSJ74
Dear all.
I am planing a UGS preamp build and I want to explore the possibility for using JFet LSK170/LSJ74 instead the BJT ZTX450/ZTX550 found in this unit. I know that BJT are current controlled and JFet's are voltage controlled, so my question is:
Does the UGS remain the same and the only difference is JFets instead of BJT's and bias adjust ?
The BOM state that JFet's are compatible; Dropbox - UGS_Muse_ugs_BOM_1.0.pdf - Simplify your life
Well, the UGS Muse edition use both the UGS Buffer (M1) and a JFet Output Buffer (M2) which I am guessing is the discrete OPAMP - (still learning). The JFet Output buffer (M2) which was developed by Flat, might now at closer inspection be the one referred to in the BOM I attached. Meaning the N.Pass UGS (M1) could stay intact and the only stage getting the LSK170/LSJ74 is the OPAMP (M2).
Not easy when certain things are called almost the same.. lol
Oneminde
