Danley J7-95 - Bose L1 compact
I notice similarity between those two loudspeakers and I wanted to share. You can see similar angles used with the drivers between the new J7-95 and Bose L1.
All about compromises for the intended purpose......sacrificing congestive interference and Fairfield performance for wider horizontal dispersion. In the case of both, an easy decision given the purpose of the system for commercial use from a compact system.
