Orion Cobalt 1-ch Class D amp goes in protect mode
i have a 1 channel orion cobalt amp CB3500.1D . when i run power to it it goes straight to protect mode .i opened it up and nothing looks blown so what do i check first the mosfets they are IRF640N ANY SUGGESTIONS WOULD BE GREATLY APP
Hi cam909ron,
Couple o' things --
- are you sure the 12V power supply can deliver enough current?
- I don't see a protection relay -- what do the speaker terminals measure during 'protect'?
- with that many big MOSFETs to drive (an IRF640 is rated 200V, 18A), the class-D IC might be somewhat protected (from catastrophic output device failure) by a layer of drivers
- depending on what 'Protect' is protecting the unit from, supplying power without the heatsinks may risk further damage -- OverVoltage, OverCurrent, UnderVoltage, dead rail, DC offset -- lotsa possibilities that are hard to assess without a manual, or at least a schematic
- what can you tell us about the history of the unit, esp what was going on when it died?
- it might get more attention (read 'useful responses') if you asked a moderator to move it to the Car Audio forum
- could you post a somewhat smaller, better focused picture?
Rick
