John Curl's Blowtorch preamplifier part III
This might be a typo?
Fourier integral transform works above a function that is continuous in time domain and the result is continuous in frequency domain. No periodicity requested.
Fourier series works above a function that is periodic in time domain and the result is discrete in frequency domain.
Discrete Fourier transform is periodic in both time and frequency domains.
Actually, you're both right. If you stare at the FFT screen long enough, and if you have enough processing power in your brain, you may be able to have the big picture, including the harmonic content vs time, and their correlation with the envelope of the note with the attack, sustain, and decay. Or chop the note up in slices and FFT each one and then try to figure out some sort of synthesis. And do it again varying the force applied to the bow.
Or just listen and enjoy. :)
<snip>
"It is not little!" you might respond in disagreement. Well, if someone is relying on the fast A/B switching feature of FoobarABX, he won't perform well.
For example we have one.wav and two.wav. I can play one.wav several times to get used to it, then I play two.wav. Once I know the difference, I can ABX the file by playing only X (or A and X). If I play A I will know if A is one.wav (or not) then I play X and I will know if X is one.wav (or not). Then I don't need to play B and Y to give my answer.
Do you know how it is possible to give answer by playing only X?
It is worth to remember that this way you're not doing an "ABX test" anymore but instead are just using a software named "ABX" to do another kind of listening test.
It should be understood that there is no contradiction between enjoying listening of music and doing measurements and analysis. Some of us do like to make both ;)
What I do not understand is the fact that we, who are interested in measurements and technology are labeled as some with limited hearing abilities and no interest in listening of music or going to concerts. It should be understood that education, measurements and analysis help us to better understanding what we hear and why we hear it.
BZZZZZT!
Fourier theorem (the foundation of the Fourier transform) does not assume or need strict signal/function continuity. Piecewise continuous functions/signals (meaning grossly that they have a finite number of discontinuities) are also good enough, provided that they have finite limits at the continuity intervals endpoints. Trivial example, a periodic ideal triangle signal is perfectly Fourier transformable.
A non periodic signal/function can either be extended to periodicity (as mentioned) or consider it's direct Fourier transform, but the coefficients will now be continuous integrals instead of discrete sums.
A Fourier series is NOT necessary the Fourier transform of a signal, otherwise said, not all Fourier series have an inverse Fourier transform in the time domain. More precise, not all Fourier series are originating in real world signals, some are a physical impossibility (that is, for example, violating causality).
Discrete Fourier Transform has nothing outstanding, is simple writing the standard Fourier transform with coefficients as convergent infinite series and conveniently truncate the result, at the price defined in the Nyquist theorem (frequencies over a certain value are lost).
Fourier Theorems | Mathematics of the DFT
Not easy to further explain these without rather complex math, you may want to check the next free reference.
He means HF oscillations, probably.
Of course, PMA.
More than this, I tried, years ago, to increase the Open loop bandwidth by compensating the hf losses at the VAS emitter* and had those kind of trouble with variations of the stability margin with temperature changes.
And this kind of problems can be tricky with a complex amplifier.
But I believe Dadod has explored this aspect in each and every detail: I think he is good enough.
* BTW: I gave-it up on this idea because the added open loop gain at HF did not made, on my listening experience, big changes in the quality of the reproduction, despite the measured measurements improvement of harmonic distortion between 10 & 20 KHz. So I keep with optimized simple 3 poles CFAs. I gave-it up too with cascoded VAS as well. But, may-be it is stupid ?
Thank you, no need, I have my own resources. You said that the Fourier transform is applied to periodic signals only (or signals extended to periodic) which is an incorrect statement - here:
And I am not going to play a QUOTE/PROOF misquote game with you.
Thanks a lot, Zung, i will ask him, but he surely knows about them. He has a real violin workshop in his house, guitars in construction everywhere. All his guitars, including his old 335 have been permanently polished, improved etc...
Then I'd really love to have his opinion, if any.
For me it's about the same dilemma as digital vs analog: on the "digital" side, I have a mass-produced Epiphone with perfect CNC cutting, machine assisted glueing and an almost indestructible epoxy finish. On the "analog" side, I have a Gibson and a Heritage, both hand made with all the little flaws, like a head nut that's off by a mm on the Gibson, or a fret board that's not quite level on the Heritage, and both have the extremely fragile nitro lacquer. But guess what: I prefer analog. :)
If you want to apply the Fourier transform to aperiodic signals and hence prefer to work with continuous integral Fourier coefficients (that usually you cannot calculate in a closed form) also lose any DFT benefits in the process, you are welcomed to do so. Sane engineers prefer to use the Laplace transform for aperiodic signals.
Just for the heck of it, the much beloved Spice simulator uses a signal periodic extension (it assumes the input/output signal is periodic from -oo to +oo on the time axis, even if the transient simulation starts at t=0) to calculate the distortions spectra.
Otherwise, do you have a point to make or you just feel like trolling?
