Laminar ports
Hello
Does anyone know how to calculate laminar ports, as I know they can be made shorter/ narrower than conventional ports because of less distortion.
all the best
August
Hello
all the best
August
You would do well to read the linked paper, perhaps some other papers as well. By narrower, I am assuming you mean smaller cross sectional areas? If that's the case, then no, that will be less linear than a larger port cross section, at anything other than small signal levels and low sound pressure levels.
Port compression effects set in at fairly low drive levels, velocities above 10m/second have been shown to cause losses.
Round ports are the most ideal shape if they can be fitted to the enclosure, second to that a square port. Rectangular ports that have a wide cross section but limited height will have more frictional losses than a round port. ( higher reynolds number )
