Marantz PM-66SE KI Signature PSU Modifications
I recently purchased a Marantz PM-66SE KI Signature (the same circuit as the PM-40SE, PM-44SE and PM-66SE, but with a toroidal transformer, a sprinkling of 'boutique' capacitors and a copper-plated chassis.
N.B. The PM-66* variants have an extra transformer winding for the remote control features.
Whilst it appeared to be fully-functional (** I normally listen with the 'Source DIRECT' button engaged **), I was concerned by the amount of heat dissipated by Q801 & Q802.
I resolved to reduce the amount of heat dissipated by these transistors with the minimum amount of circuit modifications and parts.
I noted that R802 had been replaced. I also noted that Q801 was loose! Too much heat in a TO220 package.
Marantz_PM-66SE_KI_1_small.mp4
Marantz_PM-66SE_KI_2.mp4
N.B. I had a Marantz PM-44SE that used to intermittently drop-out the speaker relay, then re-engage a few seconds later. That amplifier 'disappeared' before I could investigate the cause (I now suspect Q801 as aove).
After measuring the voltage drops across R802 (47R / ~5V drop) and R804 (47R / ~3V drop), I determined that the +24V rail was supplying ~100mA (worst case - speaker + source direct relays engaged) and the -18V rails was supplying ~66mA (worst case - ALL LEDs illuminated).
It's not surprising that (according to 'the Internet') R802 is the most common failure with these amplifiers - it's severely underrated. It's a design oversight!.
R804, D804 & D805 also take a beating in the default configuration.
** When I disengaged the 'Source Direct' relay, I lost the right channel (intermittently). Re-engaging the 'Source Direct' relay restored the right channel (always).
After replacing ALL the semiconductors and capacitors, the amplifier was completely destroyed. 😱 :mallet:
The above sentence is completely untrue and is precisely what happens when you believe 'misinformation' on the Internet. 🙄
The right channel could be restored (temporarily) by moving the large ribbon cable (WV01), but would disappear minutes/hours later.
After chasing the intermittent problem, I discovered that the (never used) 'Balance' control had been 'whacked' by a previous (l)User.
Resoldering ALL the pins restored normal operation (but for how long?).
  • Marantz_PM-66SE_KI_1_small.mp4
    5.7 MB
  • Marantz_PM-66SE_KI_2.mp4
    4.5 MB
Reactions: SquireTrelawney
Iteration 1
As I had a 5 pack of 150R/2W wirewound resistors, I replaced R804 with a 150R/2W wirewound and R802 with a 75R/4W (2 x 150R/2W in parallel) wirewound. I also removed the wire link adjacent to Q801 and installed a 75R/4W wirewound in R809 (which Marantz thought about, but didn't fit). This further reduces the strain on Q801.
Heatsinks were attached to Q801 & Q802, power applied and measurements taken.
Although the transistors were cooler, I felt that further heat reductions could be made.
Iteration 2
Criteria: 5-10mA(max) through the Zeners/6-12V(max) across R805 & R806. Minimum heat dissipation in Q801 & Q802.
R802 120R/2W(min)
R804 330R/2W(min) (350R/3W preferred, but would be a 'boutique part)
R809 39R/2W
R810 68R/2W
Unfortunately, I didn't have a 330R/3W wirewound, so I used a 270R/2W wirewound.
Now that R802 & R804 are doing most of the 'heavy lifting', I can now keep my finger on Q801's heatsink!
C801, C802 and D801 were also replaced.
Parts were purchased from RS & Farnell.
Apart from the heatsinks, no audiophool 'boutique' parts were used.
You've obviously thought hard about the problems there but there are plenty more to consider before signing off on your efforts. The design looks a bit "pieced together" to my way of thinking and seems to have had more than one person at the drawing board.
For example, C801 and 802 are under-rated. The black triangle mark for those electrolytic caps has me puzzled too. Of course, that's only what is shown in your posts, there are likely more "errors" such as that. Also, If you are planning on ignoring the significance of the fusible resistors, don't forget that they are a necessary part of the design, so think carefully about safety when using the amp or leaving it unattended when powered. Read up on them and learn a little about designs that include fusibles where specified (that's the black triangles and "!" marks.)
I had a PM66SE as my main amp until just over a year ago when it died, dead, nothing, so probably a power supply issue like this.
I replaced it with a Cambridge Audio A5 and that was sonically, quite an improvement. I gave that A5 to a friend when I got my hands on some Linn kit dirt cheap and he is enjoying it to this day.
Point being, the PM-66SE isn't all that great sonically, yes, it's a good amp, but there are better ones that are common and cheap, so if yours is proving a PITA to get working, perhaps better to move it on and get something else.
The original power transformer likely had an internal thermal fuse. If it failed due to overheating or any other reason, the transformer would wind up just as useless as it would be if burnt out due to overload.
It's not clear in your posts, but according to the voltages shown on your schematic snips, you or the previous owner must have replaced the power transformer with one that has some 4VAC higher output. If so, this would certainly be the reason for an overheating problem and failure of the fusible resistors. Is the original schematic shown in the OP with only +/-38VDC main output correct for your model? Importantly, if you persist with the transformer's higher voltage supplies, it will necessitate a re-design rather than just patching over the problem with larger dropping resistors for the auxiliary 24 and 18VDC supplies. It should also be obvious that higher voltage rail voltages to the power amplifier won't be without their problems either. Check the capacitor voltage ratings there and whether fusible resistors there are still functional too.
If the transformer is incorrect, I can't see any problem with fitting a standard dual 25VAC toroidal in place of what appears to be a stock dual 30VAC type toroidal. (if that was changed, it would have been an ill-conceived "upgrade") Then you can get back to safe operation with raw 34V rail voltages and replacing the fusible resistors with appropriate similar, original spec parts.
It's no surprise that quality, design, and cheapness has taken over once-great names like Marantz. (and many other brands too)
And all the while, these components have gone UP in price.
Sad state of affairs it is.
Thanks to greedy companies.
.SNIP
>9 months later... Apologies and corrections.
I may have previously posted circuit diagrams from a lesser model in the Marantz portfolio (probably a PM34, 40, 44 etc), which has lower secondary voltages. My apologies! :guilty: :ashamed: :ashamed:
A 230/30-0-30 (+ an additional secondary winding for the uP) toroidal transformer is 'standard' in PM-66SE 'KI' models (as 'Modified in UK' by "a gang of villains in a shed up at Heathrow" - apologies to Squeeze) - it's original!.
According to the circuit diagram (widely available on the Internet), there is a thermal fuse fitted... I've not felt inclined to unwind the transformer and investigate further.
The default C801 & C802 are 12000uF/56V audiophool ELNAs, which were nicely 'domed' on the top (I believe that they have flat tops when they come off the production line).
They didn't smell bad, but the domed tops had me reaching for my hammer and chisel.
I replaced them with these 'bad boys'.
They have no audiophool pretensions whatsoever! :whazzat:
At £6.00 a piece, the amp sounds £12.00 better...!
In fact, after 9 months of 'burn-in', the amp sounds exactly like it sounded on the day the caps were replaced! Who knew? :cannotbe: 🙄
Perhaps it's only audiophool caps that sound better after 100/200/(pick the latest audiophool random number) hours of 'burn-in' 🙄 🤐
I also replaced the bridge rectumfrier with something beefier.
The amp has been in daily use since I 'rationalised' the modification to 1 x 330R/3W wirewound resistor and 2 x wire links.
I can no longer hear Q801 and (to a lesser extent) Q802 screaming in pain from heat torture. :redhot:
Power dissipation in Q801 has been reduced by >75%! That's a WIN!
Footnote: In the late 1980s/early 90s, Marantz UK were based (NOT in a shed) in Harmondsworth, just north of Heathrow airport, hence the Squeeze reference.
Hi Hamish,
You have done a great job in getting a better heat distribution, but the root problem still remains. This PSU circuitry should never have been placed in the middle of the pcb - close to electrolytic capacitors. And even with the new heat distribution it still fires about 3W into the surrounding components and pcb.
This is also why your big e-lytes were starting to dome.
It is a known problem that these TO-220 (or TO-126) can un-solder themselves - and that means that the leads have been over 180 oC - heaven only knows what the inside silicon die temperature has been!
Further, the pcb track laminate adhesive has probably started to brittle and weaken - and that is all that holds the trannies (now with additional heat sinks) to the pcb.
I would definitely chuck these trannies for a fresh pair. Drill a 2.5mm hole in each heat sink, tap it to M3 and mount the new PSU trannies on thermal pads where they can get rid of the heat. I sometimes use a ready made wire to connect the trannies to the pcb: 10Sets 3-Pin Mini Micro JST XH2.54mm Connector Plug Socket Wire Cable Cord 150mm | eBay
Then possibly re-trace some of the steps to let these trannies take back more of the heat again?
Oh, and you should also consider to replace the other e-lytes in the surrounding area, as they most probably also have dried out by now.
I did exactly this on a 66SE a few years ago and it worked a treat.🙂
I can't remember now, but I think I actually did start to investigate whether the relays could be replaced by high-sensitive coil types (which reduces current consumption) and whether to replace the LEDs with superbright types (microamps instead of milliamps).
But, being the lazy b*gger that I am - most probably decided that it would be a solder joint too far.😎
Per
...It is a known problem that these TO-220 (or TO-126) can un-solder themselves - and that means that the leads have been over 180 oC - heaven only knows what the inside silicon die temperature has been!
Oh, and you should also consider to replace the other e-lytes in the surrounding area, as they most probably also have dried out by now...
These are excellent suggestions, some of which I have considered - I have the electrolytic caps for the amp and transistors + regulators (cap multiplier + voltage regulation) for the RIAA amp. But, I don't use the RIAA amp and I'm the laziest B*stard on the planet (and a cheapskate)! It's too much effort...
Unlike you, e.g. when you make an 'improvement' and say to yourself "What if...?" and make further improvements (I've read Improve a Rotel amp THD by 20dB! - it makes me smile!), my 'What ifs...' usually end with a few beers and forgetting about the 'What if...' for a decade or two. :worship:
The reason I revisited this thread was that I was listening to a Technics SU-V303 which I'd been using in my workplace.
At home, it was immediately apparent (due to the lack of 'bass' and the olfactory assault) that the electrolytics were well past their 'best before' date (the caps should've been performing better than they did when new - they've had >10000 hours of 'burn-in'). :devilr:
Bizarrely, the SU-V303 reproduces music with 'air and spaciousness' (I dislike audiophool descriptions) which seem to elude the PM-66SE 'KI', which has audiophool pretensions (the same source and speakers were used...).
As they both use the AN7062 Voltage Amplifier (with slightly different implementations), this briefly led to a 'What if...' moment. Then I had a beer! :drink:
I may revisit this within the next decade.
I should clarify the above statement by stating the >75% heat reduction is under 'worst case' conditions: i.e. speaker relay plus 'source direct' relay energised.
And, I also replaced R805 1k5/0.5W and R806 2k2/0.5W (it's what I had immediately available). 😱 Q801 still requires a heatsink.
:cheers:
This is an excellent mod that I copied myself. Thank you for the excellent work and detailed post.
Do you remember what you upgraded the bridge rectifier to?
I believe this was the replacement rectifier (I had a few unused spares available).
Choose something to suit your specific requirements.
Anyhow, Marantz came up with a better solution to the heat dissipation problem. The solution can be found in the PM57 / PM47 service manual.
And the cause of the claustrophobic sound produced by the PM66KI was the 'SOURCE DIRECT' switch - the audio signal passes through it regardless of switch position.
When I routed the signal from the input selector PCB directly to the VOLUME control PCB, the PM66KI sounded surprisingly good.
Good Luck!
Good Luck!
Thanks! Sadly that evening I posted I messed up trying to copy you and now have no output. I accidentally soldered one leg of R809 to the wrong path and now the relay won't click on.
This is seen often with users of some cherished brands as they believe that their brand produces the cream of the crop and any criticism is not allowed. Marantz is such a brand. Cherishing brands of material stuff and becoming fanatical "herd member" is a threat to sanity and critical thinking. I once solved an issue in an A branded device with a severe design error causing a high return/failure rate and was told I was hampering a well designed device by a reputable brand.
You did nice work! Removing R801....R804 and mounting an extra 5... 7VA mini 2 x 18V toroid + rectifier and 2 caps would have been a root cause solution though.
From your supplied picture (I do not currently have access to the circuit diagram), it appears that you have bypassed ALL dropping resistors and connected the COLLECTOR of Q801 directly to the +43V supply.
Q801 may have succumbed to the excessive power dissipation it was subjected to. Check Q801, replace if necessary and correct the error before re-applying power via a bulb limiter.
Good Luck!
Good Luck!
Thank you for your help. I installed a new pair today and still nothing. I'm stumped I can't see what other damage this bypass could have done.
Sorry to bump this hijacked thread but does anyone have any ideas what could be going wrong after the above error? I don't want to scrap it for parts just yet! Could dropping the resistors have blown the TA7317 protection IC? The relay is clean, there's lots of trace jumpers with wire but I've done them all immaculately. The traces/pads for Q801 are all broken/lifted and jumpered with wire runs. Was looking forward to this as a project amp but have spent so many hours trying to isolate what damage I've done (I stupidly held the relay down manually whilst the resistors were still dropped! I don't why I did something like that! 😳) I could use the chassis and heat sinks for a future build but wanted to ask first if anyone can help?
