RockFordFosgate P115S4
The speaker plate should be 16" × 16" (40.64cm2).
With 0.75" (19.05mm) wood, the box should be 17.5" H x 17.5" D x 22" W.
My first attempt was 17.5" x 17.5" x 22", however I can only do about 20-21" (car trunk isn't big enough), plus in your suggested enclosure I can't fit Port properly, the only way is to bend it (L-type). Taking everything into consideration inner measurements is 16" x 18" x 17.7 and the outer 16" x 19.5" x 20.5". I find it the best choice for my car. However I don't actually know about the enclosure ratios between H x D x W that is suggested in a general term to minimize resonance, etc.
Well, 16" cannot be the same inner and outer dimensions.
What is the maximum height your trunk can handle?
Here you go while I'm watching the 24 hours of Le Mans on Motortrend!
