pluplog,
Any build pics? 🙂
How do you intend to finish them - veneer?
What drivers are you using?
I'm still thinking about the finish... I'm tempted to paint them, but still deciding... I'll post up pics when I get there. I'm using a pair of Mark Audio Alpair 7a.
Just received my flatpak today
Wow… that is dramatically faster than expected. Other than US military who had theirs shipped ny the forces, you are the 1st overseas flat-pak owner.
dave
With Chris’ retirement we no longer have access to the shop, so barring some new, different arrangements we are suspending flat-pk manufacture.
I do have some stock of small flat-paks.
dave
dave
dave
Ah, I see. By small do you mean the FH Lites?
Smaller. uMar-Ken5,2 Plus. uFonkenWK, uFonkenPlus, Lance, Bloodhound. mMar-Ken7.3.
Plus demos of all shapes & sizes.
dave
dave
dave
Thanks, any of these good for the FE127 I've got? I know that's how the Fonken started, but I haven't followed the plot very closely.
No none of those work with FE127e. email me and i can send you the Fonken planset.
dave
I did get those from you a while back. Thanks Dave.
FH Lite
Hi to the forum
Main reason for posting : After reading all the pages I thought it would be good to encourage the continuation of this brilliant topic.
I am currently building some FH Lites. Almost completed.
What interests me the most is how much stuffing I should use. Obviously I can experiment with this. But, other people's thoughts would be interesting also.
I have mainly Tube amplification (vintage Fisher) and Vinyl is my thing.
The reason I ended up here is because I recently purchased a Philips AG 9016 amp which struggles to output 4 Watts. If I wore the speakers as if they were headphones I could hear them OK. Then I came across the principle of Folded Horn speakers and thought I'd give it a try.
Be nice to hear if anybody out there in the UK doing the same stuff.
This is an excellent forum. Very pleased I came across it
Jim
Hi to the forum
Jim
The damping is fairly well specified in the plans. The damping in the point is fixed but that below the driver on the front is variable based on driver/room/room position, and taste. All things you will have to play with once you are listening to them. Don’t be tempted to fiddle too much until the drivers are broken in.
dave
dave
Many thanks for your information Dave.
I'll get back to the forum and give some results as soon as I can.
Just fired up my Frugel-Horn Lites. Only packed the V sections with stuffing so far.
I didn't expect much as I know these speakers need to be run in and the correct amount of stuffing should be experimented with.
They sound very sweet straight away. My usual speakers are KEF LS50s.
My listening room is quite small and I've always had trouble with bass boom and positioning of speakers has always been critical.
Amplification, if anybody is interested, is The Fisher X-202-B. Source is TD 124, SME 3012 S1, Denon 103R. Gonna try Ortofon SPU tomorrow.
Will post again when speakers are run in. 100 hrs?
Jim
Jim
Hi Chris
The drivers are Mark Audio Alpair 5 gen 2. They are dinky little speakers but are sounding really nice already. I'll let you know how they are when I've run them in if you like.
My listening room is quite small. Not sure how they would fare in a larger room.
I have some KEF LS50s which are great speakers. But, certain recordings the bass can be boomy. I've got 8 bass traps (4 of which I made myself). Really need them in my room. They definitely help. The Alpairs don't seem to suffer from any boom thus far. But, as you would expect the bass is quiet. But, well defined.
Thanks for taking an interest.
Regards Jim
Regards Jim
Haven’t had a chance to hear the little KEFs, but am quite familiar with almost all the Alpairs, and the little 5.2s definitely punch way above their weight class.
@planet10
I recently brought my first stereo: frugal horns with alpair 7p and a Hiraga Le Monstre 8 watt amp both made by renowned DIYers in India. Yet to make the preamp: Pass b1. I was using volumio OS from my Boss DAC to control the volume digitally (it's always a loss without jumpers). All of a sudden the OS restarted and the initial starting of the OS makes a 2 second sound just like the starting sound of Windows XP. The volume goes by default to 100% and it clipped the drivers. Anything that can be done? I feel so doomed. Volumio OS is full of glitches..
Hey Planet 10, do you have any MK3 frugal horns available????? im located in the United States.
- More Vendors...
- Planet 10 hifi
- Frugel-Horn Mk3 flat-paks
