John Curl's Blowtorch preamplifier part III
I think it is very different. Amps have obvious differences between them .
I don't read audiophile revues, so, I don't know what is the fashion about DACs, but I noticed differences between them since a long time. Well, it seems they are, at least, in their dynamic behavior. It looks like it is mostly, but not only, in the analog part of them:
"Its a fact of life that sadly the array resistors on the ESS DAC's suffer from "Poor" Voltage coefficient (that is there resistance value changes with voltage across them) - VC modulation is seen as ODD Order distortion products (Change of "Gain" over cycle) - as the distortion is Odd order in nature it is not cancelled by differential summing." ©JohnW
That could explain my recent found that, sometimes, some recent DACs sounded "too much" in their dynamic behavior, making some of them impressive but fatiguing ?
Anyway, nothing I know sound exactly the same, nothing in real world is never perfect, preamps, integrated circuits, caps and even resistances. It is all the fun about electronic design and has nothing to do with fashion. Sometimes, we can measure why, sometimes, we don't know how. It can depend of various factors and what we are looking at.
As long as we will continue to measure standing waves, we will miss part of the landscape. A BIG part.
As long as we will not have a real knowledge of the human audibility thresholds, the measurement numbers will not tell so much.
All this being, of course, a personal opinion, that I believe is shared by lot of people and obvious in my book.
I can understand Evenharmonics.
Hats off ! ;-)
So where would the adjectives fit into it?
There’s the basics like, loud, detailed, dynamic ....etc.
Then there’s different levels of those like ‘very loud’ or ‘not very detailed’....etc.
These all seem fairly accepted if they come from people who are in the know.
"Fairly accepted", yes probably, but it doesn´t ensure that all parties agree on the meaning per se. So synchronizing any describing vocabulary is an essential part when doing qualitative research or communication about reproduction of music.
Then when you start attaching emotional references to a listening event it freaks out the scientific crowd......why is this, the randomness? we do live in a random world, I think there’s more relevance to be gained from studying from this angle.
I don´t think the "scientific crowd" is generally freaking out, certainly not the people who are doing research on this topic.
@ PMA,
I'm still interested in your comment:
"Oh, that one.
Thanks for your answer, but did i misread your post about it?
I'm asking because Ashihara did not show that the reason for the audibility of any high frequency content (like in the Oohashi et al. paper I've mentioned) was an intermodulation effect."
@ Evenharmonics,
So you weren't referring to anyone on this forum. OK.
It is pretty strange that you bring claims posted some place else to this forum. That is unless you've seen those claims on this forum and can quote them.
Speaking of strange; weren´t you the Evenharmonics that just recently wrote about things that allegedly happened in other forums, but wasn´t able to bring the evidence?
He did. The content with both <22kHz and >22kHz frequencies was distinguishable from that with only =<22kHz file only in case that it was tested through speaker with one driver. Not distinguishable when tested through a 2-way speaker with 2 drivers.
This is well known to us who make real tests in a real life. Make a 19kHz+20kHz test, of course you need low distortion amplifier, through a good 2-way speaker with crossover that would not let the signal to get in the woofer and a person of our age will hear nothing, provided that amplifier output has reasonable level and is not overloading the tweeter. Do the same with distorting amplifier or one wideband driver without crossover and you hear 1kHz intermodulation clearly.
If you have more questions, I will be back on Sunday evening, as I am leaving just now.
Thanks, but I can read and been there done that. ;)
But, Oohashi et al. already considered the intermodulation problem and therefore designed and used a speaker in their experiment which reproduced the high-frequency content (above ~21 kHz) with a separated ribbon tweeter (ribbon tweeter, afair).
Further, it is well known to us, who use real scientific reasoning (SCR), that one has to really carefully analyze two experimental designs (and executions) before concluding that one invalidates the results of the other if it was not a replication.
And a replication Ashihara's experiment was not, in fact, it was a very different experiment, and so one has to compare the high-frequency content, has to compare the level of the high-frequency content and has to consider the results of the auditory evaluation, especially when evaluating the reproduction of the high-frequency content alone.
No, I haven't designed modulators, but have a little experience with VHDL, Verilog and FPGA realizations.
Given that the input to the modulator is digital, and the output is digital, I don't see a problem here. They will have testbenches that could generate any conceivable input.
I listened to the clip, and Martin was not saying that their tools were insufficient to simulate this (where do you think they got those graphs from?). Martin was just saying that he didn't like what the canned 5th order modulator library/wizard spit out. Maybe you can explain why something that can be implemented in C on a microcontroller could not be "simulated" effectively.
Further, in the section of the clip you linked, Martin is explaining that their modulator does not exhibit the behavior that John seems to be complaining about.
On this topic, Marcel is the person you want to best answer your questions.
What Mallinson is saying (& JohnW also) is explained more fully in this (written by Mallinson & Dustin Forman)
As you can see he is saying the design process is not appropriately solving all use cases & the anomalous behaviour is perceived by some listeners
Secondly, certain ΣΔ modulators when provided with a rapidly changing input signal will exhibit non-linear noise behavior as they process the transient. This is because all noise shaping modulators are feedback systems and the usual design process (supported by commonly available design tools) operates to minimize in-band noise suppression while maintaining stability. This noise-optimized stable loop configuration will lead to an output that matches the input to the required degree within the requested bandwidth as expected. However this typical design process neglects the dynamic response of each state variable: there are choices of Q (and relative gain) that minimize noise but result in relatively large lightly damped resonances of the internal state variables. The consequence of this is that in a quiet passage of music the state variables of the modulator are all operating within a certain “state space” and the quantization noise shaping is described by the noise characteristics in this “volume” of the space. After a large music transient has passed, the output traces its dynamic response back to the quiescent operating point as we expect, but every state variable is also following its transient response back to its quiescent point12. During this multi-dimensional excursion back to the lower signal level the operating point traverses different volumes of the space, each of which has its own noise characteristic. Hence a very perceptive listener can hear something “anomalous” related to the transient response.
http://www.esstech.com/files/4314/4095/4318/sabrewp.pdf
More from that ESS paper above to provide some context
Because ΣΔ modulators are very non-linear systems only
approximations of performance are possible in frequency
domain simulations. Time domain simulations are useful to
verify first-order stability (i.e. that the loop does not oscillate
in the typical condition) but beyond this, simulations must be
augmented with hardware tests...............
Firstly, it is a known problem in noise shaping modulator
design that noise is not independent of DC signal level. A
graph of DNR vs. DC signal level will always rise as the
modulation depth approaches 100%. Most modulators cannot
handle 100% modulation depth and what they call full-scale
may be only 50% modulation depth, nevertheless a graph of
DNR vs. modulation depth up to even this 50% level will
show an increasing noise.
We hear all this talk about the perfection of well designed DACs & the accuracy of the design & modelling process (wishful thinking, taught in schools) but when real information is provided from DAC designers we see the picture is not the perfect vision it's made out to be.
So who's going to be first to ignore all of this technical info & instead talk about how could anyone trust information coming from DAC designers involved in commerce? :rolleyes:
Thanks to employee discounts, I ended up switching to, and installing a lot of Altec 409-8C coaxials which were great sounding little speakers.
Back to ...whatever the fuss was about.
Howie
Howie, thanks for sending me down on memory lane. I used these for my main stereo while being a student. They played VERY loud. But the tweeters burned out easily.
Ring radiator VIFA XT 25 is quite a special driver with not very good directivity pattern
http://www.troelsgravesen.dk/mark21_files/XT25.pdf
Out of axis the SPL falls rapidly from 2kHz and drop is big at 10kHz. Power response would be nothing special.
Since a ring radiator has twice the directivity of a driver with the same circumference, this should be of little surprise.
I believe this signifies the great problem in digital audio - the lack of understanding about how the 'digital concept' is implemented in the real world. (Remember digital is a concept, not a physical thing - it has to be implemented in physical things which don't behave digitally) The divorce from physical reality by relying on mathematical models leads to the sort of confusion seen here
....where do you think they got those graphs from?
As Mallinson said they plotted one state variable - that doesn't mean they can model the whole system, mathematically[/quote]
...... Maybe you can explain why something that can be implemented in C on a microcontroller could not be "simulated" effectively.
Maybe this paper from Philips research explains it?
In which it states that
"precise description of a 1-bit SDM is very difficult, a useful pragmatic approach has been developed, based on linear system theory"
Note PRAGMATIC doesn't mean accurate - just good enough.
And when evidence from listening impressions that 'just good enough' isn't applicable in all cases what is the reply? Do we go back & look at the underlying assumptions inherent in the design process or do we ignore all such listening impressions as "delusions" (Mallinson, an engineer, says he can't hear it but he trusted those who could & discovered the problem in measurements)
IMO you guys are talking about two different things a 1 bit SDM (or modulators in general are not purely digital systems, an FIR or IIR filter is.
The modulator front end is not a "digital concept". I took a lot of flak years ago (almost 30 by now) for daring to suggest a two chip converter with SOTA bi-polar integrators and comparators glued to CMOS logic. Talk about not politically correct.
www.hifisonix.com
Joined 2003
The problem is, on this thread there are a few real experts. And then there are people that think they are real experts and know everything about everything when in fact, unlike the real experts, they know only a little bit about a few things.
As a famous politician once said 'because as we know, there are known knowns; there are things we know we know. We also know there are known unknowns; that is to say we know there are some things we do not know. But there are also unknown unknowns—the ones we don't know we don't know.'
As Einstein is purported to have remarked ' . . . some things can be counted that don't count. And some things that cannot be counted do count . . .'
The heart of all SD DACs (whether one bit or not) is the nose shaping modulator. Maybe Chris is taking about something else not mentioned in Mallinson's paper & presentation - I'm not - I'm talking about what JohNW & Mallinson wrote - that the noise shaping modulator in SDM may not be unconditionally stable.
So I don't get your point SW?
Indeed, being aware of one's own limitations & the limitations of tests/measurements is all most of us expect for an honest & open discussion. So often that is not on display here - rather it's a display of ego/arrogance usually done in the guise of science/engineering - very far from scientific thinking where truth is the goal
