1 Placid HD-BP for 2 IVY?
Hey there,
On search of i2s dacs, I run over the COD and OPUS. As I need more channels, I just built both of them 😀
As I now rebuild my setup (the OPUS now also got an IVY), I play with the power supply of them. I read, that one Placid HD-BP is powerful enough for 2 IVY. Am I correct?
If yes, I was wondering if it is possible to run two different dacs from one supply so there are 4 channels in total. I use two i2s-boards (DANTE supported) for signal source. The dacs (va and vd) are separatly powered.
Will it work or will it interfere? I‘m using a 2x15V / 50va transformator for the placid.
Looking forward for your answers!
Greetings from germany,
Thorsten
Here are some pictures of my babies, waiting for rebuild.
