K1529 and J200 mosfets
The original ones look like this.
[/url][/IMG]
I was commenting on the date code, not the “ Y “ .
Yes you have to replace with the same “ Y “ or “0 “ Vgs letter code, but not the same date code
The data sheet shows the “ Y “ being the higher Vgs grouping, not higher voltage or current.
(see note 2 on the datasheet) They are 15.9 cm wide x 20 cm tall
https://www.pcpaudio.com/pcpfiles/transistores/2sk1529.pdf
The 2SK150/]2SJ201 are higher voltage and current, but the device capacitances are higher,.and they are bigger - 20.5 cm wide x 26 cm tall
They have the same Vgs groups as the 1529/200
http://cordellaudio.com/book/datasheets/2SK1530.pdf
Yes I have ordered about 60 pairs from them, last time about a year ago.
If one replace Y with O, then most surley, one has to change bias circuit for right Vgs as it's almost half of Y-grade.
But it may work depending on how low bias circuit works.
If not, bias will rise to a couple of amps and it will get hot !
Figge
