I have been thinking about doing a little experiment for fun. I have a class D amp which I am thinking of adding a resistor in series with a high efficiency full range driver.
Increasing the output impedance by adding a resistor in seriesis one of the ways mentioned by NP in his paper to improve the sound of voltage source amplifiers with regards to high efficiency speakers.
http://www.firstwatt.com/pdf/art_cs_amps.pdf
So my question is, what resistor values would you use. 1 ohm, 3 ohm, 8 ohm?
Or if you have tried this before maybe you could share your experience.
BTW, I have already built the F2J and it sounds fantastic. But I am experimenting with class D amp for a change.
Oon
Oon
The F2s have an output impedance of about 15 Ohms. Why not start there if you like the sound of the F2J on your speakers? The comparison might be interesting...
Thanks but 15 ohms might be a bit too high. Would have lost 2/3 of the power of the amp to the resistor.
I guess I could always build a resistor switch box and try it out...
Oon
Oon
Dear Nelson,
You are probably the most experienced in this field of them all....
What is your favourite output impedance for high efficiency drivers, a F1 of a 100 ohm, F2 of 15 ohm or lower for the voltage source type amps F5, F6...
Oon
Oon
Yes, fun is good.
So experiment!
Jan
I think the link went to all the articles, any particular articles you are referring to?
Oon
Oon
nothing wrong with choosing by adequate title
same - nothing wrong with reading them all
There is no favorite, only an interesting range of effects.
Adding a series resistor to your driver will change its Qts and will affect its performance especially if you already have a box designed for it. How significantly will depend on the driver motor. Something to keep in mind as well.
Care to share your observations?There is no favorite, only an interesting range of effects.
Oon
The problem with resistors is one may end up listening to resistors, rather than Df if they are different brands.
Perhaps the cleanest solution to hear what various Dfs sound like is tweaking an F7.
- Output impedance preference
