NPO/COG Ceramic
the question is about 221k ceramic. i want to use them for audio signal purpose. are they suitable for audio? i heard that Z5U, X7R & Y5V type are bad for audio signal job.
These look like single-layer capacitors, and 220 pF single-layer capacitors can be anything from NP0 to X7R. Most manufacturers marked class-1 capacitors with a stripe that indicated the temperature coefficient, black for NP0 capacitors, so I would guess that these are class-2, probably X7R. A 10 % tolerance (tolerance code K) is also more common for X7R than for NP0.
If you want to be absolutely sure, you either have to find a datasheet for this exact model or to measure its capacitance versus temperature.
