John Curl's Blowtorch preamplifier part III
Sorry Dan, I do not agree with your explanation at all. My explanation is that you have a bad connection somewhere (a connector contact?) that causes an audible dropout in file 02, 25ms long, and short distortion in file 06. All that cable alchemy is an imagination, to me, not supported by any proof. This is a repeating story.
So are you saying that when the brief technical issues are ignored/bypassed that you cannot tell any of the files apart ?
Dan.
Wow TOS, thanks for your such encouraging words and thoughts, I have thought through the same and the truths drive me forward whilst ignoring the detractors who 'don't get it' quite yet.....their resistance and scorn is borne of ignorance and worship of false idols.
On the surface this investigation is showing that particular changes in one particular audio cable can cause changes in sound, the bigger picture is far more extensive dare I say universally significant and universally beneficial.......Mr Tesla would surely understand, approve and encourage.
Dan.
Dan,
Thank you for your PM, which is exactly that ....... I mention Pavel as he is one of the few working electronic engineers out there who has the intellectual capacity to understand your line of enquiry. That he is scrupulous and rigorous in his analysis is all for the good. I wish other diyAudio members with similar skills would step forward and help you more. Nothing about audio is written in stone, and everything that we know and understand is in a perpetual state of flux. So collectively, I reckon we should all try a bit harder to understand your experiments.
I get it, (or should I say - the gist of it) but alas, some others don't. ToS
Some people still laugh at Tesla, or at least at some of his dafter ideas. Others seem to have a regard for him not far short of worship, presumably because he took on the 'establishment' even though in some cases he lost (due to being wrong). Science is like that; engineering should be too and is like that in most areas apart from audio and antennas.
Antennas? How does anything to do with antennas resemble what goes on here?
Dan aka Max Headroom,
Just keep going, they used to laugh at Tesla and his sound recordings from outer space. It would be great if Pavel proved you right, even better (heaven forbid!) if DF96 agreed with him. From the sidelines this is an amazing discussion. My perspective is:- irrespective of whether you are right or wrong, at least you continue to try.
The world is yours, so ignore the pimpletons and carry on. ToS
The later ideas of Tesla didn't pan out. Frankly speaking, they were bonkers. At the end of his life, he conversed with pigeons. Don't encourage a pathetic relationship with logic and reality. Pavel did not prove him right, he rather found a mistake in his procedure.
This is actually a very good point (better before you edited it 😉)
Is this a healthy response, really?
I mention Pavel as he is one of the few working electronic engineers out there who has the intellectual capacity to understand your line of enquiry. That he is scrupulous and rigorous in his analysis is all for the good. I wish other diyAudio members with similar skills would step forward and help you more. ... I get it, (or should I say - the gist of it) but alas, some others don't. ToS
On my opinion, the problem (if any) is not there.
It is to work on what matters.
If I had understood well, it is an other "cable sound" attempt. Well, as a cable (apart iimpedance) is producing lot less change in the audio signal than o lot of other things, better to concentrate on something with hundred time more influence.
Our speakers, as an example, that have a lot of distortion and non linearities, both in the response & group delay curves and time domain.
As I said, I have listened honestly to those files. With curiosity. First, it is difficult and painful to figure out differences in files with so poor qualities on the technical and/or artistic aspect.
I did-it and sended to Max good files to reveal different aspects of sound reproduction. Good global balance, micro and huge overall dynamic and little détails, quality of the reverb/sound stage.
That the pieces of music I use, personally to test my gears and the progress of my work. Why not to use them instead ?
Second, I do feel some differences. But i was obliged to go back and forth to figure out and stay, following the set-up and the moment, in a great uncertainty. Exactly the situation when I do a blind test listening. That I don't do any more, because, If I can't find a CLEAR difference with 100 % accuracy, I give-it up.
Hifi is supposed to be a way to listen to music. Not a fantom chase or a mystical quest.
More than this, my preferences (If any) varied from a test, a set-up, the moment, from one to another.
While I can find anytime, on any system, the differences between two DACs, by example, why to bother on cables between them ?
For me, it it like to work on the varnish of a formula car during a pit stop.
T, we have never met, so we do not know each other very well. I would agree that the Bybee stuff is pretty far out. I use his products, and so do several of my engineering and other professional colleagues. I don't expect that ANYONE here will seriously purchase and use a Bybee device. So, don't agonize about it. I just want to be FREE to speak about what I normally include in my audio conversations with others, without censorship here.
For the record, Jack Bybee is real. He has a real background in physics, including working on a number of classified 'cold war' projects when he was younger. He even was attached to Richard Feynman for a time, years ago, to update Feynman on Superconductivity. Now those are interesting stories, but not believed by most here as being even possible, so let's avoid them for the moment. I have personally known, and personally 'tested' Jack Bybee on numerous occasions over the last 25 years. Yes, I tested his honesty a number of times, yet he always came though. For example, he claims to have attended UCB in Berkeley, back in the '50's. Having him visit me in Berkeley, we found out that we had lived in the same building, him 10 years or so earlier. When he lived there, it was a fraternity, when I did it was more a boarding house for men, yet it seemed appropriate because the building was designed for a number of people, not a family.
Once, on line, when some cocky guy, a technician from some major firm (sound familiar) decided that he knew the secret of the original Bybee purifier, and said it was composed of Mischmetal (sp) that contained Cerium, and therefore was dangerous, especially if exposed to water. So, decades ago, I personally destroyed a Bybee device by opening it and deliberately exposing it to water, outside, with a fire extinguisher handy. Guess what, NOTHING HAPPENED. There was no Cerium in the product, and the guy who said it was, was deleted from the thread. Jack had already told me that it was safe to try this, but I had to try! Trust, but verify! Over the 25 years that I have traveled with, had dinner with, etc Jack Bybee, I have never found him making a phony product. He puts time and effort into each, and actually makes little or no profit, overall. His wife wants him to stop, because they are reasonably wealthy from past companies that he started and sold at a profit, but this gives him a 'purpose' in his last years. That is all there is to it.
Well Said.
Spend some time on radio websites and you will find lots of wild claims and confident assertions of nonsense about radio antennas, both from amateurs and some commercially involved in radio. The most common ones involve either denial of charge conservation ('no counterpoise' antennas) or violation of the Chu-Wheeler limit (impossibly good 'results' from compact antennas).
Tryphon,
I find myself acting as an advocate here. You are right, it is best to concentrate on what matters. What Dan is doing with his experimentation with cables most certainly matters to him, as he sees the results he is getting as part of a bigger picture. Exactly what kind of picture he is reluctant to say, and I understand this. I also agree that Dan is on, as you describe, a phantom chase or a mystical quest. But somebody has to do it, and it might as well be Dan, as he seems to be doing it rather well.
BTW, I am a big fan of yours. ToS
"radio websites". Now I understand. I'm more familiar with the scientific approach to antennas than with antenna-voodoo. My mistake.
Vacuphile,
I never said Pavel proved Dan was right, I said he was trying to help Dan by verifying and correcting the flaws in his methodology.
Next time, try harder. ToS
As I see it - I am skeptical to the tests that are not perfectly prepared and have basic flaws. IMO no conclusions can be made of them, other than that they have had basic flaws.
I also tried to find a cable influence, in a similar test, about 5 years ago. 12m of a standard cable like Tasker 121 was used. The only influence was some time delay like 70 nanoseconds (funny compared to audio numbers) and maybe some capacitive RC HF roll off (high above audio band), depending on source Zout. I am afraid it is time for me to take a several month break again, as nothing new can be seen here.
Tryphon,
Touched, since i'm not a big fan of myself ;-)
I'm not at all trying to be disagreeable to Dan. At the contrary.
But, under the rose, there was a time when I listened to my mixes in loops, returned home at night, looking for the slightest flaw.
Today, I can find others, probably major, that I did not hear at this time, too focused on the details.
Taking a step back serves as a lesson ?
