Using Bluetooth to send Line out to another Amp
Hello. I'm thinking of trying a bluetooth transmitter/receiver to send the line out of my bass amp to another amplifier/cabinet. Are there any problems with this approach such as latency ,noise, interference etc? Thanks
Yup. To name one.
Then there's the lousy ADC/DACs that you're going to be pushing your signal through. And the interference from all the other things in the same, publicly shared bandwith.
But it's worth a try for a satellite system.
Only if you want an always-on slap echo 😱
Stick "latency through bluetooth" in your favourite search engine. Now, if you're going to write all the drivers (etc) you might be able get that down to a usable point (what's the O/S you're going to use?)
But if you want a working wireless system, get an FM mike setup.
<snip>
...if you want a working wireless system, get an FM mike setup.
Agree on both counts.
I even tried small stand-alone Bluetooth transmitters and receivers, which I hoped would have less latency than a general-purpose PC running a badly engineered complicated operating system (cough Windows cough) that's doing a million things other than Bluetooth every second.
But no go, there was at least a tenth of a second's delay. Even more than normal slap-echo, actually, as it would take a glass wall 50 feet away to generate that long and loud a delay!
At one point circa 2013 I tried to help out a teacher friend by rigging up a microphone to the sound-card mic input of her Windows 7 PC, and running the output to a pair of powered speakers. The latency from mic input to line output was over a second. 😱 Without any Bluetooth.
Google turned up hundreds of almost identical complaints, and no solutions. Microsoft quality strikes again. 🙄
-Gnobuddy
