Advice on upgrading cheapish old speakers
Hello! Long-time lurker, first time poster, here 🙂
I have a pair of non-branded speakers I bought off a neighbour 15 years ago. Looking for a project, I recently broke them open wondering if I could upgrade them, as they've seen better days. The cones have tears and dints and they're sounding maybe sibilant at the top and boxy to the bottom.
I opened them up to find they have 8" Realistic 40-1286C midrange drivers and Foster 065N0500 3.5" tweeters (which I cannot find any info on).
I'm not experienced enough with crossovers to comment on what is there, but I have included photos hoping someone here can!
Would anyone have any advice on where to get started with upgrading and repairing these? I really love the cabinets and they sit on custom built shelving so it'd be a shame to just replace them!
Thanks!
replace any electrolytic capacitors. The woofers are high Q, so best in a closed box with plenty of stuffing, should improve the 'boxy' sound. try closing off the port (literally, put a sock in it!)
I have a pair of those woofers virtually new if you want them (free!!), pm me your address, glad to send them to a good home
These look like they may have potential. The drivers look adequate. The crossover is a little better than some, you might be able to build onto it.
The boxes may be contributing. Play some bass and feel the walls. Look whether there is sufficient soft damping inside. I agree with Pete about sock testing.
Planet10 is a member here and knowledgeable about Foster drivers. These go back, and continue today as Fostex. You want to know how low you can take them and how to cross.
In the mean time, find out whether the sibilance is caused by the tweeter or the woofer, or by the difference between them.
If you have a second pair of same woofers, put them on the back of the box, push-pull connection.
Awesome, thanks for the info - just how much stuffing is 'plenty'? Like, there is a bunch in there, but it's not crammed in. Should it be stuffed full and packed in?
That is so kind! Thanks, I will in a sec! 🙂
Ok awesome, I will - does this look like a correct replacement?
3.3uF 50V Bipolar Electrolytic Capacitor | Jaycar Electronics
Thanks! What should I be feeling for on the walls?
I just finished fixing up a cheap set of sonys for a friend.
Stuffing makes a big difference, I found it cheaper to buy a few cheap pillows at kmart for their polyester than a bag of stuffing at a craft store.
I was reading your thread and learning heaps. Thanks for that, that's a good tip. As above, just how much stuffing is enough? Jam it full?
Thanks for all of your help, everyone 🙂
Just remembered a common tweak for these was to tuck a small strip of polyester stuffing behind the center HF cone on the woofer. The idea is to damp the HF from that cone, which isn't really needed because you've got tweeters. May help with the sibilance,. Easy to try & reverse if you don't like it.
Acrylic dacron should be lightly packed, a little over 100% fill. Fibreglass can be stacked at around 50% fill.
Vibrations. Some will be carried to the panels via the air in the box, some will come straight from the woofer basket mount. This is most effective with a signal generator.
Initially I had it very tightly packed, the woofer actually sat proud of the enclosure such was the amount of stuffing. I think this was a little too much and removed some foam side sheets to allow the pillow to rest a little more loosely and I think this let the sound bloom a little more.
Thanks everyone!
So, I replaced the caps, stuffed foam in the ports and rejigged the stuffing (just reworked what was already in there in the end) and they sound infinitely better! Nice full bottom and no longer boxy and hollow sounding. I wouldn't describe any overly sibilant tone anymore, either. Thanks for all your help.
I'm looking into those Jantzen caps, thanks Moondog. Just went to Jaycar cause I was excited to get moving on it!
Next Q - the treble, although not overly sibilant, is maybe slightly more forward than I'd like, and of course, I can just EQ them from the amp, but I wonder if there's any way to tone it back mechanically or with the circuitry?
The tweeters are pretty hammered - I wonder if there's something I could replace them with?
Thanks again.
