Need help finding driver to suite.
Computer speakers...
2.1 system running off TPA3118 "plate" amp from eBay.
SB65 + P830855 satellites from 100Hz up.
I'm looking for subwoofer driver suggestions. Affordable would be nice. Current favourite is probably SD215A-88 in a ported enclosure of 1.2cuft.
Ideally around 85dB/W@1M or higher and impedance of 4 ohms.
When doing a woofer i alway ssee if i can better accomodate 2 woofers (ie 2x8, 2x10, instead o f 1x10 or 1 x 12) to get the adantage of push-push loading and the dramatic reducduction in box load.
I do have some designes for the 5 1/4” Silver Flutes, if your loudness needs are not over-large.
dave
Omnes W8-670Z
I had a play with WinISD and the Omnes W8-670Z last night. It looks promising. Default alignment wants 28litres and tunes to 35Hz. Port length may be an issue.
Hi Jerms,
About a Year ago I forgot to Post a couple of Pictures to this Thread:
Help recalculating ny port to a slot port, my math is ****..
..As there are Gremlins hidden in the advertised T/S Parameters that comes with this Driver:
b 🙂
