Valvewizard phono diode function and elimination
Looking at the schematic, what is the reason for C1? So far I have always been happy about getting away without cathode resistor bypass caps when not using a cathode resistor but LEDs...
This is discussed in my book. C1 is there to suppress the shot noise of the LED. Without it the SNR can degrade by several dB!
It has nothing to do with distortion; LED bias does not increase distortion in valve stages. The valves already produce orders of magnitude more distortion by themselves!
Call it as you want, but from simple regens to entire radar systems were working pretty fine without any kind of semiconductor, so why not a simple audio amplifier can't?
Why should your view, opinions, bias, etc. force others to do things in a way they don't want to? Why are you so dug down that you can't enjoy what you see in common because what you see differently drives you crazy? It's just a hobby.
Would this be right? That is to accomplish the clamping and protect the LED...
