best sub-woofer drivers
They both are decent drivers. Lowrider might give better low end performance (if tuned properly), 30Hz and up. It has more xmax and lower Fs.
Go for Lowrider if you want proper sub-bass. Requires larger enclosure tho.. Something like 200-250 litres tuned to 30-40Hz depending how low you want.
RCF LF18G401 is also really good performer for many kind of applications.
What frequency range?
Max price?
Max enclosure size? Large would allow a horn which requires different woofers than a vented box.
Enclosure type? Vented, horn, bandpass etc.
Is weight an issue? If so, neodymium magnets are lighter but much more expensive.
Max price?
i am willing to spend a maximum of $250
would like a range of at latest 32hz minimum
Max size is about 8.74 Cubic Feet
Enclosure type is Vented ,a simple design
weight is not an issue,you could say it would be an advantage since a pa monitor will be mounted on top of the sub
Neither
i am building a pa sub woofer but im stuck between 2 drivers the PRV Audio 18SW2200v2 18" and the Peavey 18" Low Rider. Im looking for sound quality and high SPL .which of these subs are best
PRV - PRV Audio 18SW2200v2 18" Professional Subwoofer 8 Ohm
Peavey - Peavey 18" Low Rider Subwoofer Speaker
For a PA sub on a budget, this is about as good as it is going to get.
P Audio SD18-1700EL 18" Subwoofer Speaker
If you want more xmax, then... WHG
P Audio SD18-1700N 18" Subwoofer Speaker
