Which 15" transducer for Altec VOT/825/A7?
:cop: Moderator note: Two threads merged and moved to multi way.
I am currently trying to model the A7 in HR. I intend to retune the port section, thats why Ap and Lpt are different from the original design (originally 1422 sqcm and baffle thickness).
I assumed 400L net internal volume, and 55 cm Lrc(average rear chamber)...
I am specifically unsure about Vtc and Atc..... but also Lrc, sincce it varies in the different parts of the cabinet. in the upper section it is rather small, but the big bulk of the cabinet under the horn section is 60 cm deep.
How does the input look, any obvious mistakes 🙄
400L sounds about right to me for actual volume. I've never simmed the A7 in HR - but every other box sim program I've used the results weren't correct unless I used a net volume of about 11 cubic feet or 310 liters. I don't know why that is, but I'm not the only one to find that.
Looking forward to seeing what you do.
Which 15" transducer for Altec VOT/825/A7 ?
Good morning,
I have been trying to model the Altec VOT cab in hornresp with a faital pro woofer that was praised for its good midrange sound.
I was wondering if anyone could recommend current production woofers for this cabinet? It will be crossed around 1 kHz, maybe a bit lower, since it is for "domestic use".
Best regards,
Bob
Oooof...... Slightly out of price range wesayso, but you are right, hopping in Europe, the builder will probably shop at thomann for convenience 🙄
i was thinking more along the lines of Faital Pro, Fane, PD, B&C,18sound, Oberton etc.......
15PR400 will work well. I'm assuming that is the model you're looking at.
Beyma 15MI100 looks like a really good option as well.
Most if not all modern drivers are designed for smaller enclosures. The original drivers had strong motors and soft suspensions. Look for specs as close to the GPA 416 if you want closer to original performance.
Having said that, technology has changed for the better. A little EQ will make most high quality midbass drivers sing in that box for domestic settings.
in the meantime, after locating the GPA 416 datasheet ,I have found this Beyma Woofer with slightly different Q parameters, but fairly low Fs and a VAS close to the actual cabinet volume.
Unfortunately the measured response curve of that beyma looks much worse (=less flat) than the GPA 416 or Faital 15PR400.....
One advantage of the Beyma according to hornresp would be that for a low tuning frequency of 30 Hz, the group delay would be less than with the faital.
back from vacation, I am again tinkering around in Hornresp trying to simulate the Altec A7 cabinet.
I have simulated various drivers, but getting only marginal differences. a few dbs here and there in the freq response, moderate variation in group delay and impedance plots.
my main gripes:
1) i want to make sure first of all that the FLH part is modeled accurately. Once I can trust that part, I can focus on the low end tuning.
2) I copied the values of Vtc and Atc from Phils original simulations. Are these correct?
3) the parameters for the GPA 416 are incomplete, missing Cms and Rms..... I'm not sure how trustable the simulation can be under this circumstance.
4) In halfspace the simulations look like a mountain range, even with the fabled GPA 416. The cabs will be used indoors, probably placed close to or in corners. In Quarterspace the responses even out considerably to a more presentable shape.
(EDIT: copied the part about woofer selection to the other thread in the multiway forum, sorry!!!)
I was looking for woofers that have reasonably similar Mms, Qts, Qes and Qms compared with the GPA 416. I was concerned if a low Fs would be necessary, but I didn't see any big differences in the simulations. I was also assuming that a low Le would be beneficial for the midrange sound. And what about Vas, would a close match to the cabinet volume bring any benefits? Any comments on my strategy/assumptions?
So far on my shortlist:
Faital 15PR400: (was praised somewhere for a great midrange sound)
Beyma SM115N
Fane Sovereign Pro 15-600LF
Fane Sovereign Pro 15-600 (yields a smoother curve than its expensive brother)
apparently I DIDN'T copy Vtc, it was calculated by hornresp from my transducer inputs. Phil had manually entered a low value for it. Also, I was able to duplicate the sharp lower cutoff shape of his simulation by setting Rg=5.1 as he did.
I played with the enclosure size, and cut it down to 250 to get rid of the valley between the low cutoff and the midbass hump. I attached a comparison of the Beyma and Fane. The Fane produces a more pronounced midbass hump, while the Beyma is flatter. I then compared different internal cabinet volumes with the Beyma, 250L to 300L, and 300L to 400L. 300L looks like a good compromise, and is probably realistic taking into account that a big and deep port will be needed that will decrease internal volume.
Hmm, strange place to put this! Just now seeing it only because of your other thread.
Regardless, at a glance, I don't see anything technically correct, though the horn response sim isn't all that far off, so got a lot to post re sims, Altec Vs GPA and other replacement driver choices with not much time all at once, hence will be posted piecemeal as time permits.
The highlights/essentials:
Vtc, Atc is irrelevant and can be left blank since it's a 1:1 CR and the driver is pistonic over the horn's gain BW.
Horn is a 110 Hz expo with a 128"^2 x 5/8" [baffle depth] conical throat.
Rear chamber is technically a two segment BLH with conical, then parabolic inverse taped TQWT and of course vented [mass loaded]. Note that the 825's open back horn cavities function as a crude band stop filter.
Recommend avoiding GPA if you want a true/best overall Altec A7 performance and find a driver with specs similar to the original 803 it was designed for [tuned to actual Fs] and only use AlNiCo spec 416 if wanting a [much] lower tuning than stock and/or use a high enough XO point to tone down the horn's output, leaving it basically a WG.
Frequency response wise, you want it to look like a lead guitar's where its breakup modes BW fills in/extends the horn's response to ~3.5 kHz/5-6 kHz F12. GPA's OTOH are nominally flat like the last of the series were, leaving the horn a ~ 'one note' honk that they rolled off using a 1.2 kHz XO to 'kill two birds with one stone' with the other of course being to get a much higher HF horn power handling.
Some measured 803 specs here: ASHLEY
GM
