So, I have modified an amp I have. 12AX7 + EL84
It is now basically an AX84 P1 circuit without the tone stack.
See circuit here:
http://www.ax84.com/static/p1/AX84_P1_101004.pdf
I don't need controls for mid treb and bass, I prefer just a single tone knob.
Can someone recommend me a single pot tone stack?
Should I just use the tone stack with fixed resistors somewhere in the middle of the range and have bass be with a pot?
See circuit here:
Fender Tweed tone control might do you.
That's the other way around from this tweed circuit I found:
Is the result the same?
TMB fixed?
I'd like to have it with a single knob. The chassis already has a hole and "EQ" printed on it 🙂
Single knob it is 🙂I'd like to have it with a single knob. The chassis already has a hole and "EQ" printed on it 🙂
The mids and bass frequencies are 'fixed' with resistors, only trebles have a pot, and you can tweak these resistors to get the mids and basses at you taste, I think.
Single knob it is 🙂
I mistook the pot for the volume, cooking while looking.
I hope I didn't leave the knife in the pie that's in the oven now... ??
I actually think this is the one i'll end up using.
Should I put it before or after the master volume?
Try a mid cut control rather than a tone control. It will clean up the amp when on minimum setting and give a little mid boost when up full.
Merlin has a version in his book. Otherwise look for the framus mid control.
Of course you can adjust the frequencies and depth to suit.
Also "TMB fixed" as above with:
-100k instaed of 33k "slope" resistor
-47pf instead of 500pf treble cap
-1MA pot instead of 250kA treble pot
These are more Voxish value which has been recently tried in a P1 , check Mike Knauf posts on AX84
I would say before but there's no wrong place to put a tonestack, depending of what kind of tone you're looking for. The closer you put it to the end of the amp, the more it will sound like a Marshall.Should I put it before or after the master volume?
I know you may have already ruled out the Tweed control, but in case you re-consider it, please be aware that the Tweed tone control is highly interactive with the volume control....this tweed circuit I found...
This means that the tone control behaves differently at every setting of the volume control. Turn the volume to maximum, and the tone control (treble boost) stops working altogether.
It works the other way too, i.e. turning the tone control will change the volume.
Imagine a car that pulls left when you brake. When you turn the steering wheel, the car accelerates. And when you accelerate, the car turns right.
Would that be fun to drive? 😱 That's what interactive controls feel like, even on your guitar amp, though not as dangerous to life and limb as the interactive controls on the car.
People aren't all the same, though, so some seem to be fine with the Tweed tone control. Perhaps some people even like the Tweed tone control. After all, there are people who like kiviak, which is a dish consisting of decomposing fully-feathered, Little Auk (bird) carcasses complete with their poop-filled intestines, stored in a sewed-up seal skin until they ferment ( Kiviak - Wikipedia ). (This would seem to be playing Russian Roulette with death by botulism.)
-Gnobuddy
Only if you use Eider instead of Auk. Or use plastic bags. At least according to the link above.😕Kiviak - Wikipedia This would seem to be playing Russian Roulette with death by botulism.
-Gnobuddy
Who doesn't like kiviak, haggish, hakarl and surstrømning?
Tweed appeals to me when you describe it like that 😀
About to work on it now, so tweed first. I can always change it.
Tweed tone circuit is in.. but my ears... I'm not sure if it sounds good.
Have to wait for my friend to listen as well. I have been using a small headphone amp the last couple of days, so everything sounds weird to me at the moment.
I apologize, I was totally wrong, the Tweed tone control is the best design, and the best-sounding guitar tone control on planet earth. You should go all-Tweed, all the time. Everything else is horrible, not even worth trying.Tweed appeals to me when you describe it like that 😀
-Gnobuddy
Here are several one-knob guitar tone control circuits to try: Amplifier Tone Stacks - monster.party.hat
And here are several more: Guide to Single Knob Tone Controls – Chasing Amp Tone
Over the years, I've read a few posts from people who built and liked some variation on what has come to be known as the "Big Muff tone control", even though the circuit actually pre-dates the Big Muff. The second link I posted shows an old Supro amp that uses it.
-Gnobuddy
-Gnobuddy
-Gnobuddy
I tried the tweed. Didn't end up liking it. I think I'll try the Big Muff.
But I might not. I stumbled across a Fender Champion 600, one of the new ones. It sounds so good. And it's even smaller, I might end up selling the other one.
And how about the kiviak, did you like that? 😀I tried the tweed. Didn't end up liking it.
Does Fender have a new 2019 version, or are we talking about the once from 2007 or so?Fender Champion 600, one of the new ones.
I'm not sure if you're looking for an amp that is physically small, or one that is playable at very low volume. If it's the latter, consider the (solid state) Boss Katana 50. In the past I have never heard any solid-state electric guitar amp worth buying, but this one seems to be an enormous improvement on all the previous few decades of crappy-sounding digital modelling amps.
-Gnobuddy
- Live Sound
- Instruments and Amps
- Single pot tone stack (EL84)
