Hi all,
Great forum. Looking to buy these Peerless full range speaker as they are cheap. Could someone recommed a box for them.
Peerless by Tymphany PLS-75F25AL02-08 Full-range
https://cpc.farnell.com/peerless-by-tymphany/pls-75f25al02-08/pls-full-range-80mm-8-ohm/dp/LS05105
Pav
Pav
Try TABAQ or 0.40x mini Karlsonator. Both should work quite well and produce nice rich well rounded bass. Mini K will be more compact and easier to place on a desk or shelf. The Sd is about 6cm2 less than a typical 3.5in TC9FD but it should work fine.
Mini Karlsonator (0.53X) with Dual TC9FD's
I am guessing you are talking about this TABAQ, http://coolcat.dk/bjoern/TABAQ_TL_for_TB.pdf
Yes, but much more info and applicability to other drivers in the main theeead here:
TABAQ TL for Tang Band
Do a search in the thread for this driver and you may find it had been simulated already.
Now, I love the TABAQs, but that driver's Qts is a bit on the high side, and you won't get the bass boost that tha TABAQs can deliver with that driver.
In this case, I would recommend XRK's suggestion of the mini karlsonators. They should fit better than in the TABAQs.
