Bill,
Okay, I see the claim about pink noise as an imaging test, which is something I could try.
Regarding LEDR, I am skeptical that that particular illusion would work for me. I have previously tried listening to simulated vertical, overhead, and behind effects played through stereo speakers and through headphones. It never sounded like motion to me, just sounded like varying EQ and an phase stuff, but always coming from the speakers, or stationary inside my head with headphones.
That in itself is interesting. Entirely possible you are wired differently to me which would explain why the illusion doesn't work.
Is that Dork Audio? I hope you noticed the antenna symbol rather than ground used on the label. 🙄
Well spotted! I had to look a second time.
It's DoUk audio with a "U". They sell some fairly decent chassis including big big heatsinks, into which I put my first "M2x" prototype: a Class A stereo amp that dissipates 80W per channel with the inputs shorted.
Wasn't that his joke? Also, that looks like an Earth symbol with the connection coming out the wrong side, perhaps that was their joke....
Mark4... The reverb tails you refer to - if this is what it sounds like it is, it should be readily measurable? Did I miss some measurements?
In principle, everything must be measurable. Still need to know what and how.
In this matter, I believe the need is to measure the accuracy of the levels of the first bits. A long work. Do we have to fear any dynamic recovery problems ?
Does anyone know who designed the IC inside the Apple lightning or USB-C headphone dongle? It appears to be a custom part for Apple. Maybe Cirrus?
I find the performance impressive for the size and power consumption.
That might be true about the chip but... The dongle, it's the stupidest blitheringly **** slap in the face to the late Steve Jobs as you could possibly make. I can't imagine a more repugnant, anti-apple ethics, thing to do. It's the equivalent of making a Tesla car that has to tow a trailer that's the battery it won't run without.
One of the DACs that loses low-level reverb tails is DAC-3. Measurements performed at Stereophile show ENOB = 21-bits. There are no missing bits as measured however Sterophile does it, and 21-bits is pretty much SOA.
It seems from my experiments with adjustments to dac registers and or AK4137 DSD sample rate, that reverb tail loss is linked to I2S/DSD clock jitter and or dac VCO jitter as function of DPLL bandwidth, at least for S-D dacs of the type most of the tested dacs are. Also, Allo Katana RPi hat DAC reproduces the tails pretty well. Interestingly, the best reverb tail reproduction of dacs included in the listening tests came from a TDA1387T based dac named phiDAC by its designer, our own diyaudio member Abraxalito (Richard). It was clocked by a Chinese CM6631A USB to I2S board. The dac chip itself is obsolete, but Abraxalito has some in stock. He is offering full kits for assembling 10 dacs for $50. So, a nominally $5 dac won that particular competition.
Measuring room reverberation is a standard technique though...
None of those surround soundy things work for me. I mean they sound ... interesting, but fake.
Fake is OK but do they achieve the desired result, the Star Trek franchise makes big use of them. Even on a cheap Kindle in the dark, above, behind, all work.
It's hard to describe - I can sort of hear what it's supposed to do, but the illusion collapses to 2 speakers as soon as I try and listen to it.
I assume it's that something in my brain knows it's a fake, and won't play ball. A bit like, once you have seen past an optical illusion, you can't see the illusion any more.
The illusion can be fragile. I'm afraid I have to take statements like Mark's inch or less width in perceived image with a pinch of salt
someone here mentioned a DAC that can be had as just pcb all the way up to completed unit without case.
I cant find it ... which was it?
It had some characteristics that should help with low level details like reverb/room sound and decay.
The lack of low level detail of DAC3 might be related to a dynamic range shift upward with the bits to achieve their greater head room at peak levels.
-RNM
-RNM
On the localisation (soundstage, stereo image...) point - people hear differently. The illusion works well for some, not so much for others, it's very much a subjective phenomenon. Same with surround sound stuff. Perhaps it's no surprise that small effects would make a difference to different people therefore - but that should still be measurable.
Have you tried running mono information in dacs?
Is there any reason why this is not level linearity? If you have 9 technically well behaving ones, and the 10th one expose more "reverb tails" I would guess it is because it's compressing (as appose to expanding or linear).
Measurements of the same model dac, Benchmark DAC-3, was described on the measurements of page of the Stereophile review as follows:
"Benchmark's DAC3 HGC offers state-of-the-art measured performance. All I can say is "Wow!"—John Atkinson"
The measurements can be found at:
Benchmark DAC3 HGC D/A preamplifier-headphone amplifier Measurements | Stereophile.com
Yes, it has no problem with low-level detail. Only imagined problems.
It? DAC-3? I did not mean that DAC-3 has linearity problems - my understanding is that it hasn't. But other DAC might have and these can be experienced as having wonderful "reverb tails" - i.e. probably compressing.
Your understanding is correct, it does not have linearity problems. It also does not reproduce audible low level reverb tails. Clearly the problem is not due to linearity. You appear to me to be thinking like an analog guy, no offense intended, understanding analog is a good thing. However, with S-D dacs it might help to try thinking like a DSP guy.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
