Did a lot of reading and use several Excel SS to calculate the size of the cabinet.
What I find is an size of 250L to 300L and a S vent of 600 cm² and about 30cm long.
Resistor 5 to 6 Ohm.
Did I do this right or has someone a better proposal?
I have 4 Altec 515-16G.
Maybe there are better enclosures for them.
I want to build a two way with a Yuchi horn on top so it has to be a reasonable height, say not above 85cm
Rob
Rob
Never heard an Onken with a 515. I'd be worried about the low end. What do your sims show? 360L was the classic size for the 416.
817/515-8G factory measurement [scroll down]: http://www.lansingheritage.org/images/altec/specs/components/515g/page3.jpg
GM
GM
The 8G has a ~37 Hz Fs, so if tuned to it, it's flat enough to be 'boomy' in some rooms and definitely when near/at a corner, so in some cases need to be either damped or tuned lower. The ~20 - 25 Hz 515s OTOH are definitely bass shy compared to the 416s except in a corner.
Size wise, the pioneer's Vas/1.44 works a treat, so ~244 L tuned to Fs with Av = Sd vents and damp to 'taste'.
GM
Better than I thought. Gotta look up the volume of an 816. 6 cubic feet, maybe?
Dunno, don't recall ever figuring it out since I learned the hard way with 210s that I don't like parallel horn walls, so chopped down 825 cabs to the pioneer's original 'one size fits all' ~6 ft^3/45 Hz MI specs. Seems reasonable then that your guess is spot on or TTBOMK certainly good enough. 😉
GM
I listen at the moment to 4 times the 816 cabinets.
They are very bass shy.
If I look to the measurements of the 816 and 817 they are very similar except SPL.
I can build a cabinet with one woofer no problem it wil be active driven.
Rob
Rob
- Onken for Altec 515-16G
