GB for Simple Cap-Mx Regulated Low-Noise PSU
With some modifications and use of flying leads to an externally mounted regulator chip such as the LT1085 you can get 5v at 3A. The capacitance multiplier will need to be mounted to a substantial heatsink as well. 3A x 3.5v is over 10w dissipation on the IRF610. Assuming you are using 12v upstream then you have 8.5v downstream and another 10w will drop off from LT1085. Circa 20w total. That’s a big heatsink. You could use a DC-DC step down and take the 12v to 9.5v then that drops less heat across the voltage regulator but still same on IRF610 (they are designed for thatbso not a problem with sufficient heat sinking).
https://www.analog.com/media/en/technical-documentation/data-sheets/108345fh.pdf
DrPro - 2 boards - USA
Vunce - 2 boards - USA
goldkenn - 4 boards - Hong Kong
Yatsushiro - 2 boards - France
Mindfunk - 4 boards - Germany
maartn - 3 boards - Netherlands
ericimage2 - 2 boards - USA
Roundtoit - 2 boards - USA
Kokanee - 2 boards - Canada
The boards have arrived and they look great. I will be sending out invoices shortly.
GB Status Update
DrPro - 2 boards - USA = Invoice Sent
Vunce - 2 boards - USA = Invoice Sent
goldkenn - 4 boards - Hong Kong = Need PayPal Address
Yatsushiro - 2 boards - France = Invoice Sent
Mindfunk - 4 boards - Germany = Need PayPal Address
maartn - 3 boards - Netherlands = Need PayPal Address
ericimage2 - 2 boards - USA = Need PayPal Address
Roundtoit - 2 boards - USA = Invoice Sent
Kokanee - 2 boards - Canada = Invoice Sent
spind -2 boards- Canada (if possible combine shipping with my Melbourne DB's-thanks)
GB Status Update:
DrPro - 2 boards - USA = Paid
Vunce - 2 boards - USA = Paid
Yatsushiro - 2 boards - France = Paid
maartn - 3 boards - Netherlands = Paid
Roundtoit - 2 boards - USA = Paid
Kokanee - 2 boards - Canada = Paid
Spind - 2 boards - Canada = Invoice Sent
Update:
Spind - 2 boards - Canada = Paid
GB Status Update
goldkenn - 4 boards - Hong Kong = Invoice Sent
Mindfunk - 4 boards - Germany = Paid
GB Status Update
goldkenn - 4 boards - Hong Kong = Paid
Thank you to everyone for providing payment. i will start shipping the boards shortly.
