Howdy,
If this should be in a different thread please feel free to move this.
I'm having trouble sourcing the Ultra Touch felt that Dave recommends in the Frugal Horn builds. It seems that I can get 2" or 3" thick pieces, but not half inch. Also It seems like Boded Logic is having production issues, at least according to one of the distributers I spoke with. In looking for alternatives, I wonder what really matters in the properties of the felt. There are many things out there to use and does the type of felt used really affect the sound quality of the speaker?
I've found 1/2" thick polyester felt for auto carpet underlayment that is reasonably priced. Does the poly give a different sound that cotton or wool? What about Homasote? That is 1/2" thick and while a rigid board is easy to work with. I appreciate any help you all can provide.
We of as of late use this product in its 13mm guise: HVAC << Bonded Logic. The black backing makes for easy installation and easy removal (leaving the black bit behind.
A little thicker than we use but would work: UltraLiner™ Sound Blanket << Bonded Logic
There are other acoustical products — all somewhat thicker than optimal.
A little thin and the aluminum would need peeling off: http://bondedlogic.com/pdf/radiant-barrier/radiant-barrier-spec-sheet.pdf
Wool felts from McMasterCarr or other felt suppliers can be looked at.
dave
dave
Some of the best sound dampening material is melamine sponge foam blocks. This is a super fine (nano structure) reticulated foam originally developed by BASF for professional sound abatement called “Basotect”. I think once the patent expired, it was a free for all. Also known as miracle eraser cleaning pads. You can buy a pack of 100 from China for $7 shipping included. They are 10cm x 6cm x 2cm thick. I don’t think any other material works better. It’s fireproof too relative to plastic based foams as melamine doesn’t burn easily. For lining the back chamber of a speaker cabinet where the rear of a cone has direct line of sight, use of this foam eliminates any “boxy” sounding signature.
Basotect(R)
You can get melamine foam from many places for example:
20/50/100PCS Cleaning Magic Sponge Eraser Melamine Cleaner Multi-functional Foam | eBay
You can get large sheets used for buildings etc but they are pricey as they come in large quantities.
Basotect(R)
Thanks!
Thanks Dave,
I spoke with the vendor in Minnesota and he seems very nice to deal with. They stock the 1/2" duct liner, and will sell less than a full roll. Did you get my latest email with construction detail questions?
Thanks Dave,
Basotect(R)
As Dave says, bigger sheets would be nice. But also you can just kinda tile the wall with the small sponges.
Bob
Thanks Dave,
Yes. I have been moving slowly these last few days as we have had a big dump of snow (after none in calender 2018) that perturbs everything.
dave
Basotect(R)
Interesting! Is anyone aware of some damping data/measurements comparing Basotec/Magic Sponges to other more common materials (like open-cell "egg" foam, or felt)? It would be nice to see some numbers or curves, especially if it would show how the different damping materials perform vs. frequency.
Damn those melamine sheets are pretty expensive at $41 plus shipping for each piece.
I buy those rubbery foam type of yoga mats at ross for around $5.00 bucks each.
Dave, I have a 1/2" x 4' x 75' roll of UltraTouch purchased through Home Depot that I plan to use as a radiant barrier in my shop ceiling but I will have plenty left over for speaker use. Does it really make an acoustic difference if the foil backing stays on? It seems like it would make applying it easier as I was planning to firmly attach it to the speaker walls with contact cement. Do you and chrisb tack it loosely to the walls with staples, in which case I would understand removing the backing?
I have some big sheets of melamine foam with grey fabric on one face. I might try lining my Klipsch Chorus 1’s with it.
The Felt Store Canada | Shop Online Craft, Wool & Industrial FeltHowdy,
– thefeltstore.com
- Full Range
- Damping Materials
