New year, new build,in progress, tone correction preamplifier with 12AX7EH schematic ADAGIO from Dr.Bora Jagodics (R.I.P.) . Second build this year .....
Alex
Alex
Hi "alex mm", I am been impressed by the schematic of your build so I put it on a simulator specially for the tone control, I built so far many tone control so I was curious, here the result.( 1st/2nd pic.) I think some adjustment are necessary because the target of a good tone control is have the audio taper potentiometers to get rather flat response when they are set halfway between maximum and minimum around 0 dB and you can see the Adagio is far away from it also there is really no one curve response flat in the middle of the plot and a lot of roll-off frequency.
A good tone stack control should work like this ( Pic 3 & 4 ).
I build many tone control from the RCA schematic and so on but the one really achieve all goals I found in this website Practical Tone Controls.
Ltspice simulator work very well with tone control circuit, I recently built the 3 tone control propose in the website and the result is outstanding and as you can see simulation and real test are very close. ( Pic 5,6,7 )
Now I think the Adagio because can be used as a pre-amp without tone control or with tone control cannot really achieve a good performance because the first stage is not a cathode follower so with hight output impedance is very difficult but I think that some adjustment on the value of the component can just give some improvement. All the best
Hi Kissabout 2002 ,
Thanks for your toughs , simulation, schematic . I will reconsider schematic, and I will try, some changes, in values of components to see how it works . This board it's a prototype and I agree for modified version. I'm not so good in theoretical things, I'm a hobbyist . Pictures from 2010 of first built tone correction. 🙂
Alex
Alex
Hi, missing in Your sim: 100K, from V1b plate to V1a cathode.Hi "alex mm", I am been impressed by the schematic of your build so I put it on a simulator specially for the tone control, I built so far many tone control so I was curious, here the result.
Hi all ,
Transformer, mechanical adapted to PCB, it's shielded electrostatic and magnetic . Power supply, and timer, work fine, also muting, and by pass relay .
Tomorrow will test with tubes in circuit. 🙂
Alex
Alex
Tone correction preamplifier at final step. It's working, was tested, and now has new enclosure . More pic's tomorrow . 😀
And inside pictures ....😀
Very nice work and PCB. Do you have the Gerber files for the PCB?
Also, I sent you a PM couple of days ago.
Thanks!
Thanks!
I try to build, a new tone correction, same schematic but new rev.3 PCB optimized tracks . Good quality components :Alps blue velvet pot's , Vishay propylene capacitors, 1% metalised resistors, shielded toroidal transformer (electrostatic and magnetic ) and selected highgrade 12 AX EH tubes.🙂
Alex
Alex
- Tubes / Valves
- ADAGIO from Dr. Bora Jagodics
