Tivoli ONE PartNumber of AM/FM Trimmer / Variable Capacitor
I searched now for hours to find an original PartNumber. No found.
In every that i find are the speak from different values....an no one had a 100% identification.
Thanks for helping
Thank you for your Tip!:)
I do all Tips before I searched the Net and writing my Post, but it doesn,t work.
I´m a learned Technican I like repair professionaly.....you know?
Please no tips from Google here.. I know them ALL for Tivoli ONE.
I wait for answer from Tivoli Support now.
ONLY numbers or values.Nothing else.
When I get this from Tivoli Support i will share it here.
But I think they dont give informations.Even tough i have Repair Business.
Mostly no Contract no parts or infos.That´s the pitty thing
Thanks at all helpers
No Spare Parts from Tivoli Audio available
Info from 06.02.2019
Tivoli Service linked to an German Service Partner to ask for Spare Parts.
This Service Partner tells they only repair or change the device.
No Spare Parts available.
BUT if someone knows in future a Spare Part number for this.Please let us know.
I have two of these. The older one (w/o the AUX in) only has a minor case of this disease. The newer is almost unusable.
The problem, as everyone knows, is that the rotor's ground connection is made through the mechanical bearing. Back in 60's these condensers used a coiled metal strip - sort of a 1-turn hairspring - that was soldered to both the rotor shaft and the ground pin. This assured connection between the rotor and ground.
I took the condenser out of the newer unit and cleaned the bearing and then applied a drop of Nye's Clock Oil. That helped a lot. But after a few months the problem started again.
I have given up on table radios (except for some old Zenith tube sets). I now use Amazon's Echo Dots; they sell for $29 and work great with an external amp & speaker (the less said about the internal speaker the better).
This is a Mitssumi Polyvaricon 2LHT-L5
check out this threads.
https://miramlp.blogspot.com/2012/11/riparazione-tivoli-model-one.htmlhttps://www.ebay.at/itm/153275871721?ViewItem=&item=153275871721https://www.electronicsdatasheets.com/manufacturers/mitsumi/parts/pvc2lhtl5-2lhtld5https://www.ak-modul-bus.de/stat/vcap4_drehkondensator_am_fm,pd0,,VCAP4.htmlhttps://www.datasheet.live/pdfviewe...s-1/mitsumi_electric_company/PVC-2LXT-LD5.pdfcheck out also this thread:
https://www.diyaudio.com/community/threads/tivoli-model-one-vs-klh-model-twenty-one.181335/
I am looking for a replacement for the used full range speaker.
