Main living room stereo system SUBS
And yeah i am fine with complex setups if it involves mostly digital stuff
up to amplifiers .
Must be some crazy advances on servo subs/amps recently ?
used to discuss with someone from here that made servo sub and amps
can't recall his name damn ...
Martys = martin logan electro statics ?
never really like the sound of those but i don't know why ...
actually researched on DIY electrostatics like 15 years+ ago
almost built some .then you know..family business etc.. 😉
oomhs : that's a crazy sub driver!! OMG!! i'll look into it ! haah
and those line arrays i recently reviewed this exact thread
interesting stuff
good construction ideas
A bit more the kinda thing i would gladly use in me living room 🙂
Good grief, no! Sub bass from 'stats? That made me laugh.
No, I meant the (full size) Marty subs of which there are several incarnations. Most now build with the Dayton UM18-22 with no mods to the box.
I don't have them (I have a quad of FTW21s) but there are many, many satisfied builders and any questions are usually answered promptly there by experienced builders. If you dig around on AVS there are many variants, such as disguised end tables, different form factors etc.
I would go infinite baffle in a living room.
Yeah, the first true sub woofer we built was a stereo pair of 20 Hz Fc, 300 ft^3 false wall IBs. Only had a few special effects RTR tapes that went this low, but the vinyl albums of the day's [mid] bass/lower mids was 'to die for', right up there with compression horns due to the driver's ~20 ft^3 Vas, 0.2 Qts.
GM
Yeah but guys that's reserved for my HT room subwoofers
i've got a double wall ( concrete ) with a stupidly large port and chamber ( to the garage )
with 16 holes for 16X 15" subs 😉
infinite baffle planar wave powa ! but that's for later
man these pics bring some old memories!!
