redesign of leach amp pcb for integrated TO-247 output devices
Lep pozdrav za MIK-a i Vinka!
As I promised, here are files of my protection system. It would have to be divided into several posts because of pixel and KB limits (max. 100KB & 1000x1000pixels) for uploads on this forum. First one is the schematic.
I must say I am impressed , I am using snips from your designs in my "mongrel" amps (your cap multiplier) and am pleased at their flawless operation. I recently fried :hot::hot: one of the amps with screwdrivers and aluminum filings ... thought I took out the speaker but lucked out.
I normally don't use the designs of others , but your "omni" seems to be perfect. I am using 78-0-78Vdc rails with a standard EF2 output stage. Has this been tested ? And do you have layout ?
OS
Thanks... good doctor , very concise .. especially the explanation ... as usual. 🙂
The whole thing is 198K/bytes below for others. I will give credit to you for this "gem". It is on the mongrel website as well.
BTW - you would not mind if I made a few "BORA voltage boards" to round out my mongrel collection. I would like to hear them myself. What voltage stages would you recommend for standard type 2EF's ??
OS
there will be one more leach,this time with OME sign and in boraomega´s version. it will not be done so soon because i started too many projects allready but the pcb is ready:
