Micro Seiki MA 707 help please
I recently bought Micro Seiki MA 707 tonearm without two weights. The slider one and additional weight are missing. So, I have a small request for the owners: If you have any of them, I would appreciate if you could measure weight and dimensions of them, so I could fabricate them according to originals.
Thank you
I have this tonearm somewhere in my mess. If I can find it, I will post the info for you.
Did Micro ever publish a graph on where to place the adjustable mass to a specific cartridges compliance ? Otherwise its just a guesstimate
David
David
Hi David, info that you are looking for can be downloaded from here:
Library Downloads - Vinyl Engine
@ Academia, - thank you man, i have weight now. If I did my math well, slider is around 14-15 gms, additional weight is 28 grams. Correct? Dimensions? 😀
Yes, those are the correct weights according to the calibration of my balance .....
Let me take the right dimensions and I'll pass them to you.
What you have to do in the meantime is to try the type of thread that leads in the end, that surpasses my knowledge of mechanics ... I do not think it is a DIN step but of English standards, you can try with provisional screws trying to screw them gently in the arm housing (female) until you find the correct one.
