You're welcome!
Yes, its low Qt 'allows' pretty much any practical taper since adding BSC can include some additional series resistance to raise its effective Qts [Qts'] to 'fill' the larger, normally lower tuned MLTL and even lower tuned, expanding ML-TQWT/ML-horn, but the constant tapered MLTL requires the least internal damping for a given bulk, tuning, hence most acoustically efficient overall, not to mention my main reason for adopting/embracing/endorsing it since 1968, easiest overall to build.
Qts' = Qts + any added series resistance [Rs]: mh-audio.nl - Home
GM
GM
Did you search this forum with no luck? Google?
Truly curious as I only had half a clue, but chose to search for them, which took me straight to a lot of dead host site pages as well as the functioning main page, but after that it became a bit of a 'treasure hunt', winding up somewhere I don't recall ever seeing or plans of speaker designs I've never heard of AFAIK. [Dr.] Scott[moose] was even busier than I thought!
GM
GM
I have read about half Curvy Chang.
Do any now about plans? Were can I find them?
Chang plans are archived… email me for the planset URL.
dave
So much for me getting an answer............. note the email link doesn't work for me: The Spawn Family of Double Horns
GM
GM
Is the plans for free?
The archived Spawn plans are free. You’d want one of the Changs… there are 3 or 4.
I would not remove the whizzer. I am no longer in favour of XO frequencies where the driver centre-to-centre exceeds a quarter wave-length.
The 98¢ whizzer trick, massaging the rim (a GM trick), zig 2-way glue on the back at the top and under the rim. And phase plugs. These have the cones done too.
dave
- Full Range
- Best box?
