hello Mr. Mile
when connecting my b500 with another device
There is a small humm ...
Keep inputs wires short and preferably screened.
Use star grounding.
B500 PSU.....
Good Day Sir Apex,
Greetings for the New Year....
Can I use PSU7 with B500. Connect Pro from amp to PRO on PSU7 ???
macd🙂🙂🙂
Good Day Sir Apex,
macd🙂🙂🙂
Good Day Sir Apex,
macd🙂🙂🙂
I Macd
Over current Protect....
Good Day Kandimba,
Greetings for the New Year. Hope all is well ???
I see now that B500 protect is different from other schematics.... I will use PA Protect from H900 design for my protection. Just have to build separate bridge rectifier and Cap filters and soft start.... no problem....PSU7 would have been nice since all is on one PCB....
Thanks a lot for your response. Will keep you posted on my progress...
macd😀😀😀
Over current detection for PSU 7
Good Day Kandimba,
macd😀😀😀
Good Day Sir Apex,
macd🙂🙂🙂
You can use PSU7 only with B500P
B500P...
Good Day Sir Apex,
Thanks for the swift response... as Kandimba pointed out...B500 and B500P protect differs. I will use PA Protect from H900 thread as you suggested before.
Is there PCB available for B500P???
macd🙂🙂🙂
Good Day Sir Apex,
macd🙂🙂🙂
Good Day Sir Apex,
macd🙂🙂🙂
B500P pcb
B500P PCB....
Good Day Sir....
Thanks for share....do you have PCB pattern for home etch, or not for share??
macd😀😀😀
B500P pcb
Good Day Sir....
macd😀😀😀
I just gone went through the the whole thread and got quite a interested in making this amplifier. I have an 80-0-80vac 1600va transformer and I would like to make b500 TEF or b600 TEF stereo at 4ohms for PA use. what upgrades or changes can I make on the following?
>number of pairs of outputs per channel
>r24 and r25 in the case of b500
>bias circuit (r23 r24 and q5)
>any other upgrades if any.
Thanks and regards
Thanks and regards
B500P Layout.....
Hi Kandimba, thanks for the layout....can you share components layout as well???
macd🙂🙂🙂
I gona try again.
macd🙂🙂🙂
macd🙂🙂🙂
You got it. It was to much information
Thanks Kandimba,
macd🙂🙂🙂
My B500 progress slowly...to much work at the moment...both channels up and running...busy with PSU and protect PCB...will post pics soon....
- 500W PA amplifier with Limiter
