UcD700 build, Separate power supply
Hi all,
Planning my first build with Hypex UcD700.
It started w that I found a beefy power supply second hand. Its really heavy. So I got thinking to put it in a separate unit and hoping for tips. What cabling to use for the 62v DC from PSU to the two amplifier units? Is coax good? I plan using wood for the PS box, should I shield it internally w aluminium? Is it useful to add a softstart (thermistor)? Any other gizmos or features that can be good to add?
Not an engineer...
Hi all,
Not an engineer...
First you need dual voltage +/- 62 v dc I guess would work.
Coax is too thin. Thickest cable you can get, also add some extra capacitors inside the amp enclosure to cope with fast transients. Thermistor would not do any good unless you have a large constant power draw say 100W while the UcD 700s will draw say 40W when idle so no.
Look at the hypex manual you need a lot more different voltages.
Ouch. So transformers for 12V and 15V also. Thanks. Suddenly a lot of cabling. Hmm.
Koifarm, great, I can use the big roll of 4mm2 cable that I havesince 20 years then that fit no loudspeaker connectors.
I will make space for and get a readymade softstart circuit somewhere. Not a thermistor.
So alu/iron shielding is not worthwhile.
The UcDs avoid bumps at on/off. Its built in. So I suppose there are no more gizmos to think about for sound quality or longevity for PS or amps? Ecxcept lots of fuses.🙂
