Power Acoustik A2400DB - Help finding parts and traces
hi,
Some parts after second transformer burned and made a big hole on the pcb. Is there anybody who can assist me find parts and traces will be highly appreciated. Thank you in advance. Attaching the pictures of burned area.
From my experience with these amps, the caps leak. The conductive electrolyte saturates the board and the board becomes conductive. When voltage is applied to the conductive area, the board heats up and burns.
I have somehow managed to create the connections through wires. i am getting the amplifier to come on. but it is pulling 2amps and without load if volume increase the current increasing too. and outputs getting hot even while idling . the waveform on gate of outputs have a dip on top. i am attaching the pictures. the driver board had plenty cold joints and i fixed but no luck.
