Painting P-Audio PH-2380 Horn
Quick question; I'm thinking of doing a 15" build with the above horn, or something like it. I want to WAF it as hard as is practical, because whilst the new other half is quite prepared to let me build whatever I want, I don't want to look at an ugly speaker! How thick can you get away with painting the horn before it is detrimental to performance?
Russ
Maybe get creative with some old school grille materials instead ?
Use a Textured Spray Paint
Use a Textured Spray Paint, many brands & colors available online and in stores like Home Deport & Lowes, like this: Rust-Oleum 7222830 Textured Spray Paint, 12 oz, Forest Green
A textured surface has been reported to be beneficial.
A few years back there was a thread about this and someone had it done at an auto paint shop with beautiful results. Not sure I'd ever find that thread, but whoever did the paint was amazing. Perfect all the way down the interior.
Of course Altec used to paint some of their horns gold color.
+1
Finding a good auto painter, and getting him/her interested in your project is an excellent idea unless you already have a good setup for spraying, and proper safety equipment.
Failing that, a good auto paint store will be able to load your selected paint into an aerosol can. I think it's even possible to get 2-part paints loaded into spray cans.
Dupli-Color Automotive Bumper paint works well on these composite-type plastic horns.
Krylon "Fusion for Plastic" is another such spray paint that works well .
I've used both successfully on plastics.
In fact ( due to their affordability ) I simply buy both types in multiple colors + sheen's to test paint the back of my paint subject ( & then choose the most appealing ).
Some very light sanding ( with 800 grit ) is recommended.
I have kept three references I have run across to a slightly textured surface on the inside of a horn being beneficial, as opposed to a smooth glossy surface.
Post #165 in this thread Smallest Footprint Horn and Driver that can reach 500hz Search for this text:"This surface treatment has a surprisingly beneficial influence"
Second reference is this ElectraVolt: Western Electric KS-12024 horn under this heading "The Western Electric KS12024 horn in more detail." dated 12 January 2018 and search for this text: "Cast aluminium has roughed surface perhaps performing boundary layer excitation (BLE) - the intentional creation of small modes which prevent larger ones from developing. Earlier in wooden horn building I was surprised that the horns sounded better before they were sanded and finished." This starts out by stating that "the KS12024 horn stands out as one of the best sounding of all small horns". It also says "in wooden horn building I was surprised that the horns sounded better before they were sanded and finished".
The third reference is this thread: Reduce mouth resonance in horn in post #29 search for this text "the idea that turbulence created in the throat and amplified by the horn, can be attenuated (or ameliorated) by a textured surface"
I thought these were interesting and kept note of them. I had originally read some other thread on the topic but did not keep that reference, wish I had. It kept me thinking about this. I believe at Romy the Cat's site there was a reference to this also.
