replacement 12 inch subwoofer ring/sleeve/rim?
where can I get some replacement subwoofer rings/rims where the screws go into to mount the subwoofer better and not metal against metal? (it goes over the edge of the subwoofer and the holes line up with the holes on the metal speaker basket.
I also dont know what its called so i dont know what to search for to find one.
One of mine has a broken off plastic piece so the only way i can screw the subwoofer in is to put the screw in directly against the metal basket. and the screws are at very different heights because of that. and im not sure if its sealed perfectly.
The correct term is 'subwoofer trim ring'.
I got results on ebay, but have no idea if they would fit your particular subwoofers as you haven't said what make and model they are.
Have you contacted the manufacturer re spares?
Can you verify that you are looking for the type of ring I have shown in the photograph?
mine are MTX Audio Terminator subwoofers 12 inch 500 watts RMS 1000 watts peak.
They are the black colored ones with the normal looking subwoofer surround.
https://www.mtx.com/c/thumbs/0018322_12-200-watt-rms-4-subwoofer.png
I Highly doubt the manufacture sells subwoofer trim ring replacements for these.
They sort of clip all the way around and you'd have to peel and pry around the edges to get them off. they are pretty on there.
