100W Ultimate Fidelity Amplifier
  • MM MC bakar gledan kroz pločicu sa strane elemenata.pdf
  • MM MC raspored elemenata.pdf
...and each of those will be supplied with APEX A-class Preamp-PSU:
I love seeing new designs from Apex that still need to be tested and modified. There is nothing better than getting to be a part of designing new amplifiers. I never post mine , but I will some day. Cant wait to see another simple yet different class A!!! Thanks Mile!
Reminds me a bit of some of the old 1980's Maplin stuff where the parts lists were occasionally wrong and you had to work what a component should be when it didn't work.
R8 is clearly wrong in first sch as that would give a gain of 1.
Hello guys I need to let you know that I'm not gonna give files anymore from any Apex designs yes I did copy the art work for my own purpose of using them to learn and build a few amps designs that are really good but "I'm not a supplier of Sprint Layout 6 files" please use only the new designs or old designs use original files from the orginal designers example Mr. Alex MM or Willy and other great designers here who design them not me, now I learn that a degree of errors can be double if the designs is copied and something might be missing or have a wrong info please don't ask me for files use only from the original designers here are great design use them I think I learn a lot and I really apreciateall the colaboration of the layout designers here thank you so much and Merry Christmas!
Best Regards
Juan
