Preamp. Symmetrical LSK489+LSJ689. ZETEX MOSFET Output.
Good Power Amplifier is not so easy to build.
Preamp is much easier.
For example use only one dual op amp.
But that is not very romantic, is it?
Building a transistor preamp should not be difficult.
Here I show one way.
Symmetrical input using LS Dual JFETs.
Complementary ZETEX MOSFET ouput stage.
Result gives fairly low distortion.
Like THD 0.001%
Building is easy using the few small transistors.
Even easier if you already have +/-12V or +/-15VDC supply.
Of course the supply should be regulated.
