Very interesting driver. Fs is very low for such size, decent sensitivity, good xmax. It looks like very good candidate for micro monitor. The only weak side is a plastic frame. Wanna put my hands on it 🙂
I have used this driver in a mini monitor and listen to it every day in the workshop. For the money it is very hard to beat, the midrange is excellent. It is not a full range driver, the breakup peak is quite nasty and it has significant sibilance if used full range. My mini monitor started off with a cheap tweeter, but ended up with the Satori tweeter because that little 4" aluminium driver sounded so good when crossed over around 2.2kHz. Incredible value for money if used as a midrange or mini midwoofer and not as a full range.
Thanks for detailed comment. How low do you think it can play without any significant distortion considering moderate volume? Can it reach to 80Hz?
It can easily reach 80Hz. I can't remember exactly what I tuned the box to, but I think it was 55Hz bass reflex. It produces a surprisingly good bass for such a small speaker. I think it was around 4L, but it was 2 years ago when I made it, so I can't remember the exact details. It is never turned up very loud in the workshop. Originally I was going to use it with a sub, but never got around to making the sub and there is enough bass for what it was designed for. Troels used this woofer for a small TV speaker with a different tweeter and he agrees with me about the excellent midrange. My mini (or micro whatever you like to call it) monitor is by a mile the best sounding small speaker I have made. Smooth detailed midrange and the Satori tweeter gives it a gloriously clean sounding treble. It seems crazy to spend more than 4 times what the woofer cost on the tweeter, but the other tweeters I tried did not sound right to me, and the Satori will easily handle a low crossover freq. The box is solid wood so it looks great as well. Fitting the crossover into such a small box was a bit of a challenge.
This is paper cone?This driver works great in a 6.5 ltr BR tuned to 60 hz!
Larry
There is no music in that 12Khz range maybe only a lost harmonic from a violin, I happy it will add some air to the music, seems it will be a romantic sound presentation.Be careful with that 12kHz peak - as an aluminum cone driver it means this will have a significant ring in the impulse response. This will add shimmer and "air" to the music that is not naturally present. Some may like that. It will also smear sharp transient detail. The CHR70 being an aluminum cone with resonant peaks will not be free of this either.
You might want to look at similar paper cone or fiberglass cone drivers to avoid this peak.
But this SB is a great FR driver, the freq chart is one of the best I have seen for hi-fi music, the only prob is the sensitivity is too low, 87dB avoid its use by small tube amps. This driver 4 ohms impedance intend its use in series only to friendly 8 or 16 ohms.
This is paper cone?
No, it is an aluminium cone.
If you like a rough sibilant treble I guess you could use it FR. I tried it FR, but could not stand the treble. It needs a tweeter.
FullRangeMan
Yes the SB 4inch I'm using full range has a paper cone! I have them at work now, listening 8hrs a day. Still sound great, very impressed with these!
Larry
Larry
I'm using the SB12PFC25-4 full range with good results! A little light on the top octave but very nice tonal balance, no BSC required. Very well built little driver, really good value too!
Larry
Larry,
You still using this a full range driver? Looks like it would be fun one to try at the $!
Greg
FullRangeMan
Larry
Larry,
Are you using the crossover suggested by SB Acoustics for the B12PFC25-4? I was looking to try and get this into a 3 liter box, but not sure if I can with the crossover components they suggest.
Thanks!
THis SB Acoustics SB12PAC25-4 could be a nice driver to connect 8 drivers in serial to a line array if they were 1 ohm impedance as the Bose 901.
You could run two groups of four drivers each in series and then connect the two groups in parallel to net an eight ohm load.
Thanks for the suggestion, Serial-Parallel no offer a good sound quality (transients are slow, image are poor), the best is parallel, the second is serial.You could run two groups of four drivers each in series and then connect the two groups in parallel to net an eight ohm load.
I've heard the following SB drivers naked and they all sound like great candidates for fullrange.
SB15NAC, SB12PAC, MW16P (yes satori!)
Despite the peaks you see past 5-7khz its not that audible as they arent really ringing. Not to my 38yo ears anyway.
I will add the SB13pfc to that list. Very low fs, and very smooth.
Greg
Good to know! I got 12 of them in Curt Campbell's excellent Uluwatu speakers but never tried them full range!
FYI powered by just a 2a3 amp, the SB13PFCs in MLTL give some of the fastest tightest bass for music!
Greg
Aha, me too! I built the Uluwatu for my movie room.
I think Wesayso would object to that.
He's got 5x5 setup and if you look at his measurements, transients are not slow....
I also built 4x4 arrays and transients were quite snappy.
- Full Range
- SB Acoustics SB12PAC25-4 full range?
