Hi Markw4,
The problem was exactly the same before the flux
That wouldn't matter to me. Sometimes bad things can get worse over time. Being able to take a good careful look can be a very helpful way to start, especially if no schematic.
Dead stuck on this! Would KILL for a schematic LOL
You may have to.
If you want to take some better pictures and clean off the flux, I would be willing to look at what you have. But, it would be up to you to make it easy for me to take a good look at. You don't have clear, well-lit, in focus pictures of the top and bottom starting from wide view showing the whole thing, then close-ups to see fine details. You might need to unsolder some things, take resistance and voltage measurements, and possibly cut one or more traces then solder them back together after the problem is found. If you can't or are unwilling, probably best to find a reputable shop and take it there.
Thanks for advice. My thoughts exactly. Will need some thought.
You may have to.
LOL will be just another notch on my belt my friend
