The driver has an EBP of 106 and Qts 0.29 - this dictates that I should use a ported enclosure. But the crossover will be 350 Hz, well above the bass region (20-200Hz) and so I have a question.
Spite not using the driver (5") in the bass region, does it still demand a port ?
I can only find a sb15nrxc30-4. Absolutely no reason to use a port with that crossed over at 350.
What I am concerned with is the right air-spring load or CMS part of it all. But perhaps I should not worry about that.I can only find a sb15nrxc30-4. Absolutely no reason to use a port with that crossed over at 350.
A back of the envelope calculation would suggest a closed box of volume around 4 litres (0.14 cu ft) used, of course, with a suitable filter.
Interesting, how do you arrive to that volume ? What I mean is which parameters do you adjust when you consider the x-point and not the Fs/Fb of the system ?A back of the envelope calculation would suggest a closed box of volume around 4 litres (0.14 cu ft) used, of course, with a suitable filter.
I will actually par this midrange with the Wavecor WF182BD03 (7") which will be used between 100-350 Hz, and the Peerless SDF-250F75PR01-06 (10") for the 20-100Hz. And I don't intend to use a port for the Wavecor either, only on the Peerless.
Still learning stuff and if you have relationship I can consider for the box calculations when x-point matter, that would be swell.
My calculations assumed a system Q of 0.7, giving Fb/Fo = 2.4 and Vas/Vb = 5 approx.
This merely predicts a suitable closed box volume for this driver in normal use.
I'm afraid I do not understand what you mean by "which parameters do you adjust when you consider the x-point".
The pioneers determined that it was by raising Fs 1.56x or Vas/1.44 = ~14.86 L/~0.46 Qtc according to Hornresp. At 350 Hz, 1st order is sufficient with a 50 W limit.
GM
I will do manual calculations, until the - which is later today - I used: Speaker Box Enclosure Designer / CalculatorMy calculations assumed a system Q of 0.7, giving Fb/Fo = 2.4 and Vas/Vb = 5 approx.
This gives a Vb of 21 liters. I know in this scenario, this will be off due to the much higher x-point, so Fs is of no concern. So, you changed some parameters or used a different set of calculations to get Vb = 5 ... that is what I am asking for 🙂 - what or how
Just discovered a tiny issue in my calculations. Anyho... Vb is anything between 4-10 liters and is adjusted by the Qtc as all of you know. Qtc seem to be the only thing one can adjust and x-point cannot be considered for the box calculations.
There you go 🙂Thanks - I was just about to check my (rough) calculations and you've saved me the effort! 🙂
The driver has an EBP of 106 and Qts 0.29 - this dictates that I should use a ported enclosure IF I intend to use the driver down to it's low-corner below the EBP range (in the stop band under the EBP octave).
Fixed it for ya. 😉 Qts is a T/S parameter that is used to model a driver in the low-corner. If you consider the EBP = Fs/Qes, you arrive at a number who's units is Hz. Go one octave higher and you have the EBP Mid-band. This [range] is where the speakers rated efficiency/sensitivity manifest itself strongly. Below this mid-band is the stop-band, or low-corner, where the sensitivity is largely determined by the low end alignment chosen by the end-user. <-- that is where T/S analysis shines. Therefore, if you cross over within the mid-band or higher, the requirements used to maximize/manipulate low-frequency output no longer apply because it is not a design requirement.
Thanks 😀 I ended up with a sealed and Qtc of 0.707 which produce a Vb of 4.25 liters or 0,15 ft^3. It will come in at 350 Hz and take over from the Wavecor WF182BD03 (7") which will operate between 100-350 Hz.
That is totally fine. I am not worried about anything bellow 350Hz. I get F3: 80,46 Hz.With an Fs of 33Hz and a Qts of .29 the closed box F3 will be in the area of 85Hz.
Well... there are a few, but the dominant ones areI am interested as to why you are using those drive units and those xover frequencies.
1. They are among the best in their class, aka 5" and 7".
2. I want to stay within the 3 octave rule when possible.
3. The 3 octave rule dictate a 4-way or possible 5-way.
4. The drivers where chosen due to designing a loudspeaker which is inspired by Aduio Physic Codex/Structure.
5. Because I have limited width available for the loudspeakers and need a side firing LF woofer.
6. So yes there is also a 10" and the top end are actually two SEAS alu tweeters which complete one another aka normal and super. Effectively making this a 5-way
- EBP>100 but X-point is 350Hz.
