Subsonic filter 80 hz
Hi , i have been reading on the internet about subsonic filters. In my opinion it have 2 advantages.
1. It will reduce excursion off the speaker.
2. I will cost less energy because low tones will be gone.
The problem is that I can't find some filters. Does somebody know something about It.
I believe you mean infrasonic filter, also known as rumble filters. They will not reduce the bass unless you actually mean a high pass filter (higher up the frequency spectrum), which will do what it sounds like you want. They can be a s simple as a cap and coil or you have the option of going active (powered by electricity)
Thanks for the info. If I use a cap and coil it will decrease bass but not the power because the bass won't go tru the speaker but it will tru the cap and coil.
If I do it active I change the input signal on the amplifier and will me cost less energy.
Correct me if i'm wrong
Greetz
OK if they are Chinese watts.
The spec says rated power 10W and maximum power 20W. I assume that means that at 10W it begins to overheat and at 20W it falls apart. I find even those figures hard to believe for a 2" driver.
PS it describes itself as a 'subwoofer'. Something which starts from as high as 75Hz is a woofer; if it were any higher it would be midrange.
Maybe the good old 'Music Power' watts as beloved of many 'Computer Speakers' :)
Have to wonder what max cone excursion theyy have ?
If I put a highpass filter on it ( between 60 and 80hz) a lot of power is going away, also 100 watt is a bit to far but 50 watt must be possible
to the OP:
I don't really understand what you mean by '100W'.
ie are you filtering the pre amplifier signal or at the speaker itself ?
What is the signal - White / Pink Noise ?
How do you know it's '100W' ?
Not meaning to be over critical - I get that you want to filter out the bottom end as lots of energy there which won't be reproduced by the speaker and is a danger to it. I do the same thing on a different scale with bass guitar amplification to cut out the 'thumps' etc.
