Remote preamp volume control choice
Choose instead a stepped relay ladder volume for best result.
It is a good idea in theory.
To get a -90dB control in 0.5dB steps will need 180 relays? It may be a bit bulky, not say expensive to implement. A -90dB control in 0.5dB steps may not be necessary. What is a generic implementation like? Did anyone make a PCB and BOM for it? Thank you for the information.
...To get a -90dB control in 0.5dB steps will need 180 relays?...
"20 Questions"
128dB range in concept.
Say "43.5dB"
Is it more/less than 64dB?
Is it more/less than 32dB?
Is it more/less than 48dB?
Is it more/less than 40dB?
Is it more/less than 44dB?
Is it more/less than 42dB?
Is it more/less than 43dB?
Must be 43.5dB. Seven steps.
What is the pros and cons of CS3310 digital volume control vs. a motorized ALPS potentiometer?
The input resistance of the CS3310 (same as a PGA2311) is 10K. For me this is a good thing as higher resistance potentially increases noise. Power consumption is 70 mW. The main pro with the CS/PGA is that they can provide gain if needed - up to+31.5 dB. You will not get that with motorized pots or binary attenuators without an opamp anyway. The CS/PGA gain is not always there like an external opamp. The gain of the chip is controlled by a stepped attenuator inside the chip. Channel tracking is well under 1/2 dB at any setting with a 256 step size of 1/2 dB. It also has a hardware MUTE. I picked up 5 DIP for $13 out the door.
The con is that it must be loaded with a microcontroller but that is trivial with an Arduino. I have a system running that listens to IR remotes (can be easily changed to nearly any brand). I use LG but it works with Samsung simultaneously too. Anybody wants the code just ask.
Look at amb’s a10 preamp and volume control boards.
Are you referring to this?
The α10 Stereo Pre-amplifier
The δ1 relay-based R-2R stereo attenuator
Remote selector and volume control on ebay
I found a package on ebay at a reasonable price. The 63 dB volume attenuation should be adequate for most preamp application.
HIFI Remote volume Controller peramp pre-amplifier audio 128 steps /4 way input | eBay
I like the 308mm enclosure depth which would allow easy addition of buffer card or upgrade of transformer. Any first hand experience of this stepped relay ladder volume unit?
