okidoki
will contact each of you , prior to shipping , just to ask for that specific - parts just for B. M25 , or SissySIT , or both
Doesn’t make sense to not ask for both options does it? Especially since I already have Harris and others to play with. Please make my order Sissy/Babel compatible.
Just wanted to ask where others are sourcing their input trannies from here in the US...are the Cinemags the preferred flavor?
I am not sure they are all the same thing. Not sure how ZM is implementing here as well. The turns ratio on the parts is different AFIAK.
Sound wise, IMO - Edcor from M2 listening, others from F6 listening
Edcor - Steel laminations - not most detailed, but makes everything sound pleasant on not feel like your missing anything.
Jensen - Well loved and respected. Sounds most ethereal and spacious. Slightly more detailed.
Cinemag-Hi Nickel Version - very detailed, yet sounds more gutsy than the Jensen.
So all kinds of music - Edcor,
Classical, vocal, Jazz - Jensen
Electronica, Rock , but fine with everything - Cinemag.
Take it, my ears have experience, but also age. I probably don't hear any highs anymore, so it could scream at 15k-20k I probably will not notice.
Thanks for your impressions Tea.
Zen says in M25 thread that flavors are:
......4 options for signal autoformer (pinouts for all present on pcb):
-Edcor PC series 600:15K (same one as in original M2) , thus having gain of 6V/V
-Edcor PC series 600:600 , thus having gain of 4V/V (edit - only for this one it'll be needed few exacto cuts of traces and few tiny wire bridges soldering ;same physical layout of pins as previous one , but different electrical connection needed ..... very hard to accommodate without too much complication )
- Jensen JT-123-FLCPH (same one as in F6) , thus having gain of 4V/V
-Cinemag CMOQ-4LPC (same one as in SIT-3) , thus having gain of 4V/V
I am in the same boat as you with my hearing. I like to spend a quiet evening listening to Gardot, Kent and the like and any effort I spend spinning vinyl usually focuses on Jazz. However, I love R&B and my current set up just doesn’t have the stones in the right place for it.
It may have more to do with my TB W8-1808 coming up short in terms of sensitivity with the ACAs I built and put in the system a few months back. The bottom end extended a surprising amount, but they sound muted or dull compared to the gainclone I was using previously with the TB. The gainclone had an obvious hole in the mid bass region with the same speaker set up and I was trying to supplement with just a subwoofer.
It could also be that I am using the DCB1 I built as a pre. I’ve read that others have had better results with the ACA in having a pre with some gain especially when using speakers that had lower sensitivity. The only other option I currently have is an old Audible Illusions preamp that I would need to re-tube and do a few other things to. I don’t remember reading any comments about what pre has been most successfully used with the M2 or any of these related amps.
Right now I am trying to get through some work on a different arm for my table so I can try some MC carts. Afterward, I can finally try setting up some more sensitive Lowthers I have to try with the ACAs.
The Jensen are readily available, I’m going to give a call to Cinemag later.
hm
better to keep technical related posts to tech. thread .......
however , due to really minor differences in tiny parts , whoever ordered Babelfish M25 kit package #2 , will also get few difference making parts for SissySIT
who ordered SissySIT #2 option , will get what's needed for SissySIT - why sending IRFP240 , when you don't need it ..... and I can play with them
Sorry Zen...got typing and diarrhea of thoughts...please delete as you see fit...I understand your point about the kit contents
Finally getting all parts in quantity during next week .
Well, in my neck of wood , getting ACS Hall chips promptly is sorta complicated .... in fact just slow , not complicated
Anyway , during next week I'm going to visit my Eywa ....... and parts will be piled up while I'm away
So , next weekend (not this one , logically) BigBadaBoom soldering action - ZM against all those little Bugs, Day of Triffids ..... JFet Snake Attack ..... whatever
Then packing and shipping .... of course - First paid - First served
in few days starting shipping
past the middle of soldering small bugz in first batch of kits
after that sorting small parts and packing is trivial
to remind (you, me , all) , with B. M25 I'll send few parts of difference to SissySIT , so you choose what to build
... in middle of several projects ........
Russellc
why is this so familiar ........ 🙂
Finally , packing and shipping time
Today packed one , just for giggles (my fave sentence in last time , dunno why 🙂 )
Will proceed tomorrow , then to Post Office ....
Will PM or e-mail each Greedy Boy after sending , with Tracking No.
Each package sent declared as gift , no value specified , Air Mail , with Tracking No.
Found a way that bubbles are going in double layer
what, every f***ing resistor in it? thought you hate that "have you BOM" thing and that's even more, you'r really lovely guy!
sleep two days,
best
st.
sleep two days,
best
st.
well , thought it's easier to send them all , than to answer every 5mins on questions "can ya put my Shinkoh here ?"
naaah ..... you can't , leave Shinkoh for dryer machine
