Hi, All.
I'm using XSIM to model crossovers and baffle step corrections post amplification. I'm taking the measurements from REW and importing them. My question is, what software can I use to take the same measurements, and model an active crossover or baffle step correction at line level? I don't want to use inductors either due to size constraints.
Let me know!
Let me know!
LspCAD 5.2 and 6.0; SoundEasy, LEAP, Calsod. You can also use circuit simulators such as TINA, but the dedicated x/o software can optimize your circuits and take .frd files into the optimization
Also freeware for x64 is available. Should not be essential to list commercial programs which are discontinued, running on 32-bit Win only or medieval DOS.
Hello Kimmosto,
Does your -magnificent!-VituixCAD allow optimization of freely configurable analogue circuitry (opamp-r-c circuits)? With freely configurable I mean any non standard analogue circuit.
Eelco
Eelco
Yes, any connection with R, C, L and OP amp with single ended output. Transformers are not yet available.
Hello Kimmosto,
The beauty of the Old School Software is in the Optimizer. Look e.g at the LEAP Tutorials. I am probably mistaken here, but I was under the impression VituixCAD does not have an Optimizer.
Please, please tell my I am wrong.....
^Both versions (1.1 and 2.0) have Optimizer for axial and power responses (adjustable weight between axial and power), driver's SPL response or filter transfer function. Targets of SPL and power responses are tilting straight lines. Target of driver's SPL is textbook slope (or straight line). Target of filter transfer function can be external file or captured gain response from some other project/driver. All parameters of components can be optimized. Constraints are total impedance and max gain (ver 2). Optimizer is using Nelder-Mead (amoeba) algorithm -> iteration step is not adjustable.
Optimizer was introduced in ver 1.1.21.0 (2017-12-13), but it is slightly improved to version 2.
- Design & Build
- Software Tools
- Active Crossover Modeling
