Hey all.
When I connect internal DC power or SE input/output I use a drill to twist 2 wires which creates a twisted pair.
What is the best technique for balanced signal (3 wires), or bi-polar PS (3 wires)?
Straightforward options seem like:
1) Twist 2 of the 3 and have the 3rd by alongside independently.
2) Twist all 3 together with same drill technique
3) Braid the 3 ?
What is the best option?
Thanks in advance
3) Braid the 3 ?
Thanks in advance
Balanced signal is two wire, twisted pair, not three.
The third is a ground that may or may not be used and it is usually used as a screen or separate wire for want of another way to connect or keep it tidy.
Yes, never use braiding unless impressing friends takes priority over things which actually matter like signal integrity.
Inside the chassis, you might use:
a] For a ± DC power supply, a twisted 3 wire cable.
b] For a balanced interconnect, a Shielded Twisted Pair (STP). The shield might not be necessary. a third wire does not make a shield.
c] For an unbalanced interconnect, a co-ax cable.
Thanks all for the help.
Speedskater, I want to make sure I get this correctly.
For DC, I currently have a twisted pair for +/- and another single wire for GND. Is this OK for DC power, or should I twist all 3?
Based on your post, for balanced signal, the additional wire is meaningless unless its a shield?
Think of it as:
a] +DC
b] Common DC
c] -DC
They all carry DC current, so twist all three. (and AC noise currents, for that matter)
The word 'ground' is a very confusing word. indeed.
a] +DC
b] Common DC
c] -DC
- Design & Build
- Construction Tips
- How to hook up internal balanced signal and power cable
